Hi all,
I am using YazFi to host some IOT devices on a wifi network isolated from my main network. I have just started tinkering with HomeAssistant, which is running on my main network. I have the IOT network configured to allow one-way comms from the main network to the IOT network, but not the other way around. However, with HomeAssistant devices need to push/post data to the server, which is not permitted.
I tried using the 'port forwarding' setting in my Asus router (RT-AC68U) to forward the HomeAssistant port (8123) to my HA server. For security, I limited the source port to the sending IP address (ie: the device on the IOT network). After I configured this, it worked... for a while. Following a reboot, this no longer works.
I have two questions:
1) Is YazFi meant to work with Port Forwarding this way, or was it just a weird anomaly that I got it working temporarily?
2) Can I allow an entire subnet (/24) in the 'source ports' field?
