It is but its still £200+ in the UK for the ones that support AC. It would be attractive if you were in the US but the cheapness hasnt yet spread. Everything in the UK is either the $ replaced with £ and/or hiked in price.No, it's not. Did you even look?
UAP-AC-LITE $89, UAP-AC-LR $109, UAP-AC-PRO $149
Very competitive.
+1 on posting.....I'm thinking of moving to a pfsense box + access points and these look perfect!Thanks for posting this. That looks really interesting! I wonder how well they work. Those prices pretty much blow Xclaim off the planet lol.
No. Except for canada no country imposes an export tax. When you import something in the UK to sell theres the 20% VAT + 7% Import Duty. That means the item should be about %30 more which should be slightly less than replacing the $ with £ on the price.@System Error Message : Is it correct to assume that the price increase in the UK is due to Tariffs / taxation?
Very nice, but I wish they had ZHO on this line. Sadly lacking.
Thanks for the summary Stonecat. The app is just for setup and doesn't replace the software controller, correct?And they're about to release (if they didn't yet)..an app for your smart phones....so you can set them up.
Unless I've missed something, so long as it works with Wifi, it works with Ubiquiti's ZHO implementation, there is absolutely no client involvement in the hand-off at all. Some other manufacturer's that isn't necessarily the case.
Like JoeJoe said, these are under 100 pounds in the UK. Your looking at the previous V AC AP on Amazon. These new AP's are more competitively priced.No. Except for canada no country imposes an export tax. When you import something in the UK to sell theres the 20% VAT + 7% Import Duty. That means the item should be about %30 more which should be slightly less than replacing the $ with £ on the price.
If you look at the price of it on amazon UK (for the AC ones) you will be shocked.
| Thread starter | Title | Forum | Replies | Date |
Using Ubiquiti Airmax Omni 5G (AMO-5G) antennas with currently available APs? | General Wi-Fi Discussion | 6 |
Welcome To SNBForums
