moron+genius
hi SNB will there be any review on TP Link Archer C2600 coming soon? Interested in this product but would like to know it's performance before buying. Thanks.
TP-LINK verified the RAM and flash capacities.
Well, that's an slightly odd choice by them then. For this cost of the router, I can't image it would cost that much more to add a little extra flash.
So normally routers use a compressed OS image that is uncompressed into RAM. This generally works fine, but it's also why it's so slow to save settings on many routers. This thing seems to be using SPI flash as well, which is comparatively slow to something like parallel NAND or eMMC, but it's easier to implement and usually costs less.
Many smartphones do the same thing with the firmware image to maximize space for user apps...
In any event, since NAND cannot execute in place (NOR can, but NAND can't), we pop the image into RAM on bootup - with a compressed image it's actually faster to do that than to copy an uncompressed image over...
That's a possibility. But the R7000 bridge used as test client has had its firmware frozen since it was put into use.However I'm wondering R7000 performance is better because the client is another R7000, better compatibility?
Any router can be used as an access point.I read the review and also a couple other reviews and could not find out if the router in supposed to be used as an Access Point with its default software?
Hi snb-user.
Could anyone answer this for me?
Also as maron+genius said is the R7000 really better than he C2600 comapred to its wireless performance?
I would also like to know if the C2600 is better than the R7000 or not. I have owned a R7000 for about a year and a half. It's really screwed up right now. It constantly and randomly disconnects device and I have to go through all kinds of rigamaroles to get them reconnected. It's been a couple on months now and nothing I tried works to resolve the issue. The Netgears have only a 1 year warranty. So I ordered the C2600 for 188.00 on an Amazon 1 day sale yesterday. Probably wouldn't have even thought of the C2600 if not for the sale ad. It's scheduled to be delivered tomorrow but I already have buyers remorse. I do not want to go backwards in performance. So is the C2600 a downgrade from the R7000? Also any suggestions in the $150 to $250 range that is at least equal to the R7000 in performance? Thanks
Welcome To SNBForums
