D
Deleted member 22229
Guest
Is this an Asus version of Firmware that will not allow you to back out of, if installed? (FCC - Post June 1, 2016)?
What do you mean by locked down? If you install this you cannot reflash to Merlin or older firmware or something else.All of the 380_3xxx firmwares are locked down, as well as any future release. It's also written on the changelog.
I have heard they're on their way.You will need to wait for the newer Merlin builds to be able to flash...
Yes, that is exactly what it means (for now).
There are ways to go back just not through the admin/upgrade page of the GUI.
You should revise this to "through the GUI" as there are methods to go back.
Welcome To SNBForums
