Read on SmallNetBuilder
On the wireless side, the big news is we're retiring our trusty NETGEAR R7000 AC1900 test client. Although the exact new standard STA hasn't been selected yet, I can say it will be a 2x2 device. The reason is to more accurately represent the lower throughput users see from actual devices, most of which aren't 3x3.
Retests will be with latest released firmware.It would be great if the retesting including the latest official firmware of old, but currently selling models like the RT-N66U, for example.
So you think the Router Storage test results are too low?If I can make a suggestion: replace the Startech HDD dock with a closed USB enclosure for USB disk sharing performance tests. An open dock is pretty much a worst-case scenario when it comes to EMF, and is most likely skewing results toward the worst. Might be a good time to replace the HDD with an entry level SSD as well, as I expect routers will start to move beyond single gigabit performance in the very near future.
The key thing the dock provides is eSATA. That's needed for NAS testing and was needed for the new Linksys WRTs...
So if router has an eSATA port you guys are good with me not testing performance through it?
eSATA is still common on new NASes.
Ok, guys, got the point on storage. Any other comments on the other aspects of the preview? No griping about lack of IPv6 testing?
There aren't really test process "point releases". Any process change resets the Charts and Rankers. I try to not do that often because then products can't be fairly compared and ranked.regarding IPv6 - always figured that would be an item as a 'point release' of the test process once that's sorted by the different test equipment vendors...
I still don't see IPv6 as a big issue in the U.S. If it were, router makers would have better and more consistent IPv6 feature sets.
Welcome To SNBForums
