AC68 and 378.55 Speed and Kernel
geonjay
Hello.
I was recently blessed by my local carrier with an upgrade to 1Gbps - we have FTTH but they've just opened it up to 1Gbps. I was on 374_42 but had to upgrade because that version of code couldn't hit Gbps speed. I went to 378.54_2 and it worked perfectly. I've noticed that my NNTP sessions have been slower lately, and it hit me that they'd slowed down about the same time I upgraded to _55. I logged into the router while downloading and ran a top (I know, it's a huge resource consumer itself...but it works for troubleshooting) - anyway - I saw these two processes at the top of the stack. When the download completed the CPU went back to normal (<1%) and those processes disappeared back into the stack. I ran a speedtest and they popped back up.
3 2 admin SW 0 0.0 0 31.3 [ksoftirqd/0]
277 2 admin SW 0 0.0 1 29.5 [kworker/1:1]
I've disabled all of the Trend DPI stuff - even the filtering (there's a new bug in there somewhere...but I won't post about that now..I had to disable it earlier because it was blocking EVERYTHING on one of my kid's tablet) but the speed limit is still there. I can hit ~160Mbps via NNTP (using 50 active connections from a reliable usenet service). I'm just curious to know if those kernel processes should be consuming that much CPU and/or if there's anything I can do to increase the speed? Thanks
Check the Tools -> Sysinfo page to confirm that HW acceleration is still enabled. Some other features can cause it to be disabled for compatibility reasons.
HW acceleration is enabled. On another note - I've noticed that 1 of my LAN connections has started flipping from 1Gbps to 100Mpbs. Unplugging/replugging the wire seems to fix it for a while. I've never known that line to be dirty but I'll look into it.
It's official - one of my AC68 ports has become unreliable. I can hold 1Gbps using LAN port 3, but going back to port 4 introduces some weird instability and the link eventually goes to 100Mbps.
The port may really be bad, but I would flash the latest firmware available and do a full a proper reset to factory defaults. Do not use a cfg file to load your settings. Do a minimal and manual configuration to secure your router and connect to your ISP and do not only a reboot (two or three) via the gui, but also a hard reboot (physically pull the power plug and wait for a couple of minutes before power up the router again).
Did you test with a different LAN cable too? Did you try a different brand / make of cable? The end connectors wear out too.
