Access services via HTTPS
Loxion
Hi all,
Not sure if this is a QNAP thing, a general web thing or something different (I am very new and learning this stuff).
I have Ombi running in Docker on the QNAP (TS251D) and everything was works fine.
I had a domain linked to it (originally running through No-IP for DDNS services and) and that worked fine using HTTP, all traffic was coming in on specific port. I am double NAT'd so had the incoming port mapped from the modem (actually a router setup as just a modem) through to my actual router (Asus RT- AC85P), then forwarded from there to my NAS on the port OMBI is using. I am double NAT at the moment as my ISPs router (TalkTalk) is garbage and has numerous known issues, but I needed something to provide the modem functions to the ASUS which I can config better.
I then wanted to take it a step further and set it all up to use HTTPS but am having some problems.
I have setup a new domain which is HTTPS enabled using Lets Encrypt. I have setup web forwarding for that domain directly through to my home IP on the same port for testing, but it doesn't work. I get a response telling me "The Connection for this site is not secure"
I did previously have MyQNAPCloud disabled as I never needed it, however did enable it last Friday as I may have needed to access it from my parents. That is the only thing I have changed on the server, disabling it again does not resolve the issue. MyQNAP Cloud is also using the default Lets Encrypt certificate.
Should point out I can't even get in using HTTP now, not sure if there is some setting that has been changed somewhere that I am missing?
Can anyone give me some pointers or things to look at?
I suspect this is may be a relatively simple thing and I am falling foul of my lack of experience.
Any help appreciated.
