A few months back I installed 2 MoCA devices (Actiontec Bonded MoCA 2.0 Ethernet to Coax Adapter) in order to get internet speed through my coax cable since wifi would not reach. It worked great, high speed internet through my coax cable with no latency. The only problem was that after I set things up my cable boxes could not communicate with each other so the xfinty x1 system would not work. Comcast sent out a great tech who somehow isolated the MoCA conection so that they it longer interfered with the DVR and satelite cable boxes. I now find I need an additional MoCA connection in the basement. Purchased an additional MoCA device but it would not work. I tested the adapter by trading it with the working one and it was fine. Something the comcast tech did to isolate the signal is probably the issue. I tried the adapter in several coax terminal point through the house with the same result.
Is there a way to fix this issue? An Idea what the comcast tech did to isolate the signal and any way to extend that to the basement where I want to add the new box?
All coax cables for each room terminate at the same point outside the house. Thanks for any advice you can give
cjb4
cjb4
