[Official] RT-AC87U Firmware version 3.0.0.4.378.9383
Advis
Should be dropping in from orbit right now:
- Release Notes –
- Added Movistar Triple VLAN profile in IPTV setting page
- Fixed too many repeat information in system log.
- Fixed Traffic analyzer issue UI issue when changing the data.
- Added workaround for Android devices power drain issue.
- Fixed Adaptive QoS bandwidth setting issue.
- Fixed low samba transfer throughput issue when enable bandwidth limiter.
- Fixed web history related issue.
- Fixed abnormal bandwidth increasing in bandwidth monitor.
- Fixed VPN client UI issue when using Firefox.
- Fixed wireless channel issue when set 2.4G channel in 12 or 13 (only for EU region)
- Fixed dual wan ping time watch dog issue which might cause .false fail over to secondary wan.
- Fixed Bandwidth monitor and Web history UI issue which was caused by "<" or ">" in SSID.
Download
RT-AC87U
- Release Notes –
Download
RT-AC87U
This one has new QTN driver? Or just the workaround regarding power drain? ...
Sent from my SM-G900F using Tapatalk
Mine has been borked for ages, they said they can't replicate it...thus forced to use BT Home hub with 87u as AP.
Only in this 9383 release all other previous are working including Merlins builds. Merlin had this problem a while back but was sorted out. The betas in this forums IPTV for BT/Plusnet are borked too. They have messed with the igmproxy somewhere.
I see they released it form my AC56R.. any other owners of this router install yet? I just installed 9313 a week or two ago and haven't noticed any real problems with it.
Is in this FW was 100% official resolved battery drain on Android 5GHz ? Was added new driver for QTN ?
Ok i tested and by about 7h drain battery about 10% and driver for QTN in this FW are still the same as in 9332 (old driver)
When source code was moved to code 380.xxx as for model RT-AC68U...?
And is all fixes from VANIC beta 9366 was implement to 9383 ? Becuase in beta Vanic all works ok but in 9383 still is some bugs.
In 9383 when i go back on TA to other date and select client example in green color and then go to date today TA show first info about client which use more data and show name client in other color and color data is also in other.
The RT-AC68U was moved because it needed a new SDK.
Why?
But RT-AC87U dont need new SDK?
