bash history
Chrysalis
The shell I want to remember my command history between sessions, anyone worked out a viable way of doing this?
As well as preserving logs especially between reboots.
Would very much like this!
OK, this works for me. Not sure this is the best way to do it. Correct me if I'm wrong.
With Entware installed do:
opkg update && opkg upgrade
opkg install bash
Edit /tmp/mnt/sda1/entware/etc/profile
Note that my histfile is in /tmp/mnt/sda1/history/.bash_history
Edit if necessary.
# Please note it's not a system-wide settings, it's only for a current
# terminal session. Point your f\w (if necessery) to execute /opt/etc/profile
# at console logon.
export PATH='/opt/usr/sbin:/opt/sbin:/opt/bin:/usr/local/sbin:/usr/sbin:/usr/bin:/sbin:/bin'
export TERM=xterm
export TMP=/opt/tmp
export TEMP=/opt/tmp
export HISTFILE=/tmp/mnt/sda1/history/.bash_history
export HISTCONTROL=ignoredups:erasedups  # no duplicate entries
export HISTSIZE=1000                   # big big history
export HISTFILESIZE=1000              # big big history
# Save and reload the history after each command finishes
export PROMPT_COMMAND="history -a; history -c; history -r; $PROMPT_COMMAND"
# You may define localization
#export LANG='ru_RU.UTF-8'
#export LC_ALL='ru_RU.UTF-8'
export TERMINFO=/opt/share/terminfo
Just check that your /tmp/etc/profile has these entries. If the are present all is OK.
[ -f /opt/etc/profile ] && . /opt/etc/profile
[ -f /jffs/configs/profile.add ] && . /jffs/configs/profile.add
Now we do the big trick by telling which shell to use when booting (from busybox to bash):
Create or add to /jffs/configs/profile.add
[ -f /opt/bin/bash ] && exec /opt/bin/bash
Reboot and happy bash history!
Edit: Removed Entware package bash-completion. No longer available.
Is this still valid?
How do we save the command history and use it on other terminal?
Diversion does keep a shell history by default.
To keep it across reboots without installing bash (using the built in ash)....make a /jffs/tmp directory if you don't already have one
add to /jffs/scripts/services-stop
# Save ash history
cp -f /tmp/home/root/.ash_history /jffs/tmp/.ash_history
add to /jffs/scripts/init-start
# Restore ash history
cp -f /jffs/tmp/.ash_history /tmp/home/root/.ash_history
