[Beta] RT-AC68U/87U/3200 9.0.0.4_380_2295-g1423616 Beta for checking bug in Network Map
for me this function can show only port speed. Other is impossible like said Raw316 and vanic.
Hi VANT,
According to your system log, the reset flag from nvram was set to clean client list.
And the flag did not unset by the networkmap daemon, the suggestion is making factory default to unset some unused nvram values. If you still have the same problem, please sent feedback to @ASUS_ASUSWRT.
Thanks for your applying.
I will upgrade to the new fw 9460, do factory default and test.
Thank you for the good work and commitment in improving the fw.
I mean to show negotiation port speed for connected devices. Not speed at the moment as is show for WIFI clients. For LAN client should be change column TX and RX and put one column SPEED PORT.
I also upgrade FW to 9460 and test... also thanks for good job in improvment FW.
And very thanks for add new icons devices and labels Name, IP, MAC, Device
Very Very thanks :) Good Job
Please add some icons for AV RECEIVER-AMPLITUNER,
Raspberry Pi
and device to Inteligent Home.
EDIT
In new beta 9460 button close works perfect :) Thanks
BTW
Correct info in thread name from 9458 to 9460.
new fw and strange view under IE
square border around checkbox (yes/no)
under ff no problem
Maybe this icon:
Av Receiver
Inteligent home
Good option is add features Block Interner Access Time Scheduler to edite devices in LAN>DHCP Server...
Now is only in NetworkMap.
Now looks as:
Should look as:
next bug.
In AIProtection/parental controll i can't see all my offline client. i see only two, but i have much more defined in dhcp/static
But maybe it show offline client which in past was connected but now is offline. But maybe your client offline which you dont see never be connected to this router with new FW after update.
I add all my client to dhcp/static so when is not connected then is offline. Earlier this work ok.
Without this is not sense becouse we cant add device to aiprotection without connection. This list should show all devices defined in dhcp/static list as before.
You are right.
I don't know which fix to ascribe this to, but with the latest beta firmware, I seem to be getting stronger signal and faster speed on my 5ghz band.
Upgraded from 9313 to test if networkmap was still crashing with my Hikvision cameras.
Had to disconnect the cameras first to be able to get into the GUI - upgrade went fine.
Glad to report that so far it's still working fine even with my cameras plugged back in - yaaaay!
Nice one buddy - 3 months late but I suppose we got there in the end!.
Look forward to an official release with this fix implemented. thanks.
PS - Not tested anything else to be honest so unsure if the problems mentioned above are affecting my config.
EDIT: - Can confirm all connected devices are not showing in the GUI :( - I have one of my hikvision cameras, a TIVO box and a Samsung TV on a switch in the other room - The camera and the TIVO box shows fine in the GUI but there is no sign of the Samsung TV....
Media Bridge Clients appearing under one client within the map in addition to the bridge itself. . Wasn't always this way. I used to only see the clients individually and not the bridge itself (which I would think would be the way it should be)
Seeing this on RT68U/87U/5300 with an 88U as the Media Bridge
Also noticed that even though media sharing is disabled - my router is showing on my other devices as being accessible.....
@Raw316, I'd like to try this but can you update it to be based off 3.0.0.4.380.1031?
Hi westmc,
We will base on 378-xxx to develop, ASUS are doing some modification in 380-xxx, so it is unstable now. We hope we can focus on specific issue, there are no other issue will effect our debug.
Thanks,
Vanic
Yes, after factory default work ok.
