Hi all guys,
I am ASUS software R&D, Vanic. Few one know me and most of people don't, @RMerlin and @ASUS_ASUSWRT can confirm my identification. What I want is to check issue in [Traffic Analyzer -> Statistic], if any issue about that, you can contact with me privately. I will update information to this thread.
Something to clarify:
1. Traffic analyzer is not real-time, record database in each hours
2. At first usage, we will help to record database in 10 mins (you just wait for 10 sec, you can see the traffic, but after 10 mins, it won't record.)
3. Traffic analyzer works with ntp sync, if you never done ntp sync, it has no data.
4. When you use DownloadMaster or USB or something will write / read IO, it will make the time of loading data longer, in my simple testing, it spends 5 sec to complete showing traffic statistics. (my database is 3.5MB for 3 months recording with 5 clients.)
5. The database size is 30MB in /jffs/
- store into USB storage is still not to implement
- other space is used to save other database
6. We will consider to do some GUI modification about Traffic Analyzer in future work, but we are proceeding to refine some GUI style in other pages now.
Beta firmware:
https://www.dropbox.com/sh/oa03sdqmhc41rtj/AABtZzxZcMjLYolt8f03nlnza?dl=0
How to debug:
1. upgrade to beta firmware 9.0.0.4_378_9481 (updated in 2015/12/30)
2. after 2 hours, save your system log and mail to router_feedback@asus.com
3. *MUST* describe what problem you face (updated in 2015/11/16)
- If you don't find any bug and face any problem, not need to feedback.
4. *MUST* add mail title with [Traffic analyzer issue] (updated in 2015/11/16)
- If you don't add mail title for me, I can't search for this mail, and then I can't debug.
Known issues:
1. After a long time recording, you click this page, it shows very slow, it's because of GUI loading data.
=> won't do anything in 378 firmware (should be faster now!)
2. Switching traffic analyzer's unit : bits or bytes
3. MAC / IP mapping to correct hostname
=> should be fixed in 378-9313 or beta firmware 9.0.0.4_378_9332
4. After changing "Display for" or "Show by", it make traffic larger and larger
5. After clicking "Last date" to select other date, sub-traffic chart show nothing
=> fixed in beta firmware 9.0.0.4_378_9332
6. clicking the future date, traffic chart should show nothing
ex. today is 2015/11/16, when you click 2015/11/17, traffic chart should show nothing.
=> fixed in beta firmware 9.0.0.4_378_9332 (updated in 2015/11/16)
7. when "Display for" is app, and change "All apps" to any app type (ex. Dropbox), traffic shows nothing.
=> fixed in beta firmware 9.0.0.4_378_9366 (updated in 2015/11/24)
8. when "Display for" is app, and change "All apps" to any app type (ex. Dropbox), sub-traffic chart has wrong title.
9. when "Display for" is app, and change "All apps" to any app type (ex. Dropbox), and select back "Display for" is router, show nothing.
10. when "Display for" is app, select the fifth app in top 5 chart, and then change "Display for" back to router, if router's client is less than 4 client, will show the old fifth app traffic in top 5 chart.
11. click "Apps" -> click today, it will show clients in sub-chart.
How to duplicate?
a. 12/16/2015 + apps + click green color
b. select today 12/16/2015 again
c. show first device name + green (two errors all happened!)
=> postpone 2~3 weeks to handle (updated in 2015/12/15)
=> fixed in 2015/12/29 (updated in 2015/12/30)
Bugfix in beta firmware:
[bugfix] switching display for “router” and “apps”, “All clients” should interaction with “All apps”
[bugfix] display for Apps and select certain apps, pie chart shows no data
[bugfix] fix bandwidth monitor will be 16383.x suddenly
[bugfix] spam log : start NTP update
[bugfix] spam log : mastiff log message
[bugfix] adaptive qos : customize will show nothing after some setting
Suggestion: (2015/12/02)
1. time scale change into 0~23, not 1~0
=> not to modify, but we will consider in future work
2. add clear button
=> you can delete by yourself via command : rm /jffs/traffic.db, it will make all data clear, so be careful if you don't want to make traffic disappear.
Others: (2015/12/04)
Update RT-AC68U beta firmware here, it's only for AiProtection VP and FTP issue, and it includes all bug fixes here. Don't feedback any information here, please mail or have a conversation with me, make this thread clean.
Note: only Traffic analyzer issue, please don't feedback others.
Thanks,
Vanic
Beta firmware:
How to debug:
Known issues:
How to duplicate?
2. add clear button
Thanks,
Vanic
