CTS/RTS Asus AX86U Pro
marcd5123
Hi Guys ,Sorry if this has been discussed already.
The RTS/CTS setting as it's default is basically set to disabled at 2347.
Has anyone played around with this and set it much lower and see if they experienced any difference as obviously this is designed to help or stop any fragmentation of data sent . With it set to 2347 my understanding is everything is going and coming at the same time which may or may not be causing fragmentation to the data so the router WiFi won't be working as efficiently as it could be ??..
So guys any of you tried this and had any good or bad results.
