XIII
Part of the Furniture
Every version of the PuTTY tools from 0.68 to 0.80 inclusive has a critical vulnerability in the code that generates signatures from ECDSA private keys which use the NIST P521 curve. (PuTTY, or Pageant, generates a signature from a key when using it to authenticate you to an SSH server.)
Therefore, if you have a key of this type, we recommend you revoke it immediately: remove the old public key from all OpenSSH authorized_keys files, and the equivalent in other SSH servers, so that a signature from the compromised key has no value any more. Then generate a new key pair to replace it.
The good news: the only affected key type is 521-bit ECDSA. That is, a key that appears in Windows PuTTYgen with ecdsa-sha2-nistp521 at the start of the 'Key fingerprint' box, or is described as 'NIST p521' when loaded into Windows Pageant, or has an id starting ecdsa-sha2-nistp521 in the SSH protocol or the key file. Other sizes of ECDSA, and other key algorithms, are unaffected. In particular, Ed25519 is not affected.
