Disabling Guest Wifi at night?
mrvoidman
I'm looking for a shell script to disable a guest wifi SSID that I can schedule using cron. The parental control feature is too specific for my needs.
I have a RT-N66U running 3.0.0.4.374.35_4. I found the following commands on another post but they don't seem to do anything:
# Disable
wl down
wl ssid --cfg=1
wl ssid --cfg=1 ""
wl up
# Enable
wl down
wl ssid --cfg=1 "OLD_SSID"
wl up
Any other suggestions? Can a script change the password to lock people out and set it back again later?
# Disable
wl down
wl ssid --cfg=1
wl ssid --cfg=1 ""
wl up
# Enable
wl down
wl up
Schedule a cron job using:
http://forums.smallnetbuilder.com/showpost.php?p=66327&postcount=2
and the commands/techniques to change the Guest SSID passwords are shown in
http://forums.smallnetbuilder.com/showthread.php?t=22700&highlight=%2Fdev%2Furandom
I suggest you comment out the nvram commit from your script; for something that will run every day, it's not really needed and may have an adverse impact on your flash memory longer term
Considering that the router is only "committing" a couple of small changes, are you sure that premature nvram failure is a concern?
Commit is only needed if you are applying a setting which you wish to survive a router reboot.
