john9527
Part of the Furniture
FixRelease Update-10E1
I just put up Update-10E1 into the FixRelease download at
http://1drv.ms/1xeeBvS
This corrects a formatting problem with the VPN Server Details page that causes options for both PPP and OpenVPN to be displayed. This is cosmetic problem only and an update is not required unless you are setting up a VPN Server for the first time (existing servers will continue to operate normally).
On the base Update-10 you can workaround the problem by toggling the server type to PPTP (and back if you wish to use OpenVPN).
Sorry for the problem.
