salam2009
Hey guys,
On 12\3\2014, I tried load balancing but it didn't work whatsoever!
Here was my scenario:
" I have 2 modems (both are the same) with 2 connections taken from the same ISP, one is connected to Router's WAN port (as Primary) and the other to the 2nd LAN port as Ethernet LAN (Secondary).
I've selected Load Balancing with the default settings. The problem is that the right LED light is turned into RED and I get internet drops out a lot!
I had no trouble using a single line with dual WAN turned off!
All I hoped for is to make the router gives the 2nd line bandwidth to the 2nd internet request (i.e. youtube video/2nd download instance of IDM, etc.).
Should I change 3:1 load balancing configuration to something else? "
I also found this in some forum at that time:
"ASUS RT-AC87U dual WAN is still work in progress for load balancing!
As for failover, it's only applicable with 3G/LTE USB modems and not with another WAN ~ work in progress.
Teaming is still work in progress as well."
Now, does the new firmware v3.0.0.4.378_6117 which claims it "Fixed dual wan connection issue when both primary and secondary wan connected to cable modems" would really solve my issue this time?
If yes, what about the load balancing configuration question mentioned above?
Your help would mean the world to me!
Thank you so much!
Cheers,
Salaam
Thank you so much!
Cheers,
Salaam
