Is my RT-AX57 bricked ?
fab404
Hello,
My RT-AX 57 only shows the power blue led, nothing more, nothing less.
I cannot enter rescue mode, or reset.
Even if I try to power on with the reset button or wps pressed, it just light on the power led. Nothing happens.
Is it bricked ? What should I do ?
Hello,
What happened to put the router in this state ? I would check the power supply if that shows ok then trash it.
Nothing special.
I plugged it, setup and stuff, was working, then nothing. It was put in this state the first time I used it.
What do you mean by "check the power supply" ?
Return it.
