Hi all. We recently had a Comcast tech come and check everything out because of unexpected speed slow downs in the evening time. Upon checking signal levels and all cables, the tech said he was seeing noise in the line. I told him and showed him that I used MOCA adapters and he determined that is where the noise was coming from. This was NOT the problem of unexpected slow downs as we found out by completely bypassing the MOCA setup and hooking directly to the modem. Upon having the tech tell me that there was noise in the line from the MOCA adapter he said he couldn't willingly hook the MOCA adapters back up because of the noise, but left that decision up to me when he left. I have decided to use wifi for now, but I'm wondering if I should just go back to the MOCA's and try them again even though there is noise. I have posted 2 pictures of my setup and tried to make it as clear as possible. First, is my setup correct? Do I have everything hooked up the way it should be? If I don't please let me know what I'm doing wrong. Second, do you think I should hook them back up or just go the wifi route? Third if I do hook them back up should I maybe change the frequency that they are operating at or do they automatically go above or below what frequency the modem signal is in the coax line? Thank you for your time and any recommendation(s) you can provide.
***EDIT***
Actually thinking about this a little bit more I think I have the main room setup wrong, but correct me if I'm wrong please. Is this how it is supposed to be?
http://i.imgur.com/kEEWJMC.jpg
***EDIT***
