maxbraketorque
Anyone know?
It's the name of the Broadcom platform used by their newer models starting with the RT-AC86U. Typically means the CPU is a BCM490x or a BCM675x.What does 'HND' stand for (and what it mean)?
Sooooo... Now I'm confused if HND started with the RT-AC86U but the RT-AC68U is a far Older router. How could the older router possibly be a HND???It's the name of the Broadcom platform used by their newer models starting with the RT-AC86U. Typically means the CPU is a BCM490x or a BCM675x.
The bhnd driver provides a unified kernel bus interface to the on-chip interconnects used in Broadcom Home Networking Division (HND) devices.
The Broadcom HND device family consists of SoCs (System On a Chip) and host-connected chipsets based on a common library of Broadcom IP cores connected via an internal hardware bus architecture. Drivers for these cores are implemented against the unified bhnd interface.
The Sonic Inc. Silicon Backplane used in earlier HND devices is supported by the siba BHND driver.
The ARM AMBA-based interconnect used in later HND devices is supported by the bcma BHND driver.
The RT-AC68U V4 is a major hardware revision. One of the nice benefits is it gets AES hardware acceleration:Sooooo... Now I'm confused if HND started with the RT-AC86U but the RT-AC68U is a far Older router. How could the older router possibly be a HND???
ASUSWRT-Merlin RT-AC68U_V4 386.3_alpha1-g0d9656cad9 Thu Apr 15 02:26:35 UTC 2021
admin@RT-AC68U-E100:/tmp/home/root# cat /proc/cpuinfo
processor : 0
cpu model : ARM
BogoMIPS : 100.00
Features : fp asimd evtstrm aes pmull sha1 sha2 crc32
CPU implementer : 0x42
CPU architecture: 8
CPU variant : 0x0
CPU part : 0x100
CPU revision : 0
processor : 1
cpu model : ARM
BogoMIPS : 100.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0x100
CPU revision : 0
I recently just bought myself a second RT-AC68U from Amazon.ca to try AiMesh & use as a Node. Your post had me hoping I got lucky... so SSH'd into the Node through my older one & into the newer unit...The RT-AC68U V4 is a major hardware revision. One of the nice benefits is it gets AES hardware acceleration:
Code:ASUSWRT-Merlin RT-AC68U_V4 386.3_alpha1-g0d9656cad9 Thu Apr 15 02:26:35 UTC 2021 admin@RT-AC68U-E100:/tmp/home/root# cat /proc/cpuinfo processor : 0 cpu model : ARM BogoMIPS : 100.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 CPU implementer : 0x42 CPU architecture: 8 CPU variant : 0x0 CPU part : 0x100 CPU revision : 0 processor : 1 cpu model : ARM BogoMIPS : 100.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 CPU implementer : 0x42 CPU architecture: 8 CPU variant : 0x0 CPU part : 0x100 CPU revision : 0
And also 128 KB of nvram instead of 64 KB.
That new model should be hitting retail around now or in November (it got delayed a number of times in the past).I recently just bought myself a second RT-AC68U from Amazon.ca to try AiMesh & use as a Node. Your post had me hoping I got lucky... so SSH'd into the Node through my older one & into the newer unit...
BOOOO...
Apparently no aes for me ;-(
I can already see the threads "I can't flash", "problem with my 68U", 'Which Version are you running?"
They did. The RT-AC68U firmware now contains both images in a single file. Which is a bad idea IMHO, because routers that are low on free memory will experience even more difficulties than before to complete the flash. This is why I am considering on my end to release both images separately.That is a valid point that someone over at Asus might not have considered...
他们做到了。RT-AC68U 固件现在在一个文件中包含两个图像。恕我直言,这是一个坏主意,因为可用内存不足的路由器在完成闪存时会遇到比以前更多的困难。这就是为什么我正在考虑分别发布这两个图像的原因。
Welcome To SNBForums
