Is this Normal temperatures for RT-AX86U
SuperFreaky
2.4 GHz: 48°C - 5 GHz: 50°C - CPU: 73°C
uptime of 7 days with 388.1 installed on my ax86u, (it has been running flawlessly thanks @RMerlin )
not worried just wondering if these temperatures are normal thanks.
Completly normal if your room is a bit warmer and well within normal range...
I get the below with 24C ambient temperature - standing on my office desk (so no airflow restrictions)...
2.4 GHz: 45°C - 5 GHz: 46°C - CPU: 68°C
Pretty much the same here:
It has cooled down a bit but that’s with the air conditioner on, it’s been a hot summer so far here in Australia
Ahhh, it's a bit colder here...
Windchill makes it feel like -17 right now.
Fans : ID-COOLING TF-9215, 92 mm, Ret 12v, 0.3A ---> 5v USB3
Frame : Fancover for ASUS RT-AX86U
The result: A drop of 15% without load and 20% under load.
1. Idling
2.4 - 46, 5 - 53, CPU - 68
2. Idling + FAN
2.4 - 39 (15%), 5 - 45 (15%), CPU - 54 (20%)
3. Load AX+AC +LAN 10 min, 300gb of data
2.4 - 50, 5 - 57, CPU - 75
4. Load AX+AC +LAN 10 min, 300gb of data + FAN
2.4 - 39 (16%), 5 - 49 (14), CPU - 61 (19%)
