qacafe-matt
Hi -
First post, but I'm avid SNB reader. Thank you Merlin for the wonderful firmware!
I've been testing the latest released build (RT-AC56U_378.55_0.trx) on an RT-AC56U. I believe I have found an issue with local name resolution. I have the DNSFilter feature enabled and working with 'OpenDNS Family'. This appears to work perfectly and does in fact redirect all DNS queries, even those sent directly to other DNS servers, to OpenDNS. This is makes it very difficult for local users to bypass the filtering which is a great feature.
The issue I've discovered however is that when DNSFilter is enabled it seems that local name resolution stops working. In fact, all local name queries are sent to the WAN DNS servers (OpenDNS in this case). Disabling DNSFilter results in local name resolution working as expected again. Is there a configuration option that I need to set for both DNSFilter and local name resolution to work at the same time?
-Matt
-Matt
