Lost internet connection?
bayern1975
hello, i have problem with connection. i lost it using merlin 380.57 firmware, 2.4Ghz disabled, NAT disabled.....What is going wrong?
Mar  6 14:00:51 kernel: SKIPPED false Type 1 Radar Detection. min_pw=10 pw_delta=0 pri=90612 fm_min=0 fm_max=0 nconsecq_pulses=3. Time from last detection = 74756, = 1245min 56sec. Detected pulse index: 0
Mar  6 14:18:24 pppd[515]: No response to 10 echo-requests
Mar  6 14:18:24 pppd[515]: Serial link appears to be disconnected.
Mar  6 14:18:24 pppd[515]: Connect time 1262.9 minutes.
Mar  6 14:18:24 pppd[515]: Sent 402579779 bytes, received 3156443671 bytes.
Mar  6 14:18:25 dnsmasq[1054]: read /etc/hosts - 5 addresses
Mar  6 14:18:25 dnsmasq[1054]: read /tmp/mnt/sda1/adblocking/blacklist.txt - 2 addresses
Mar  6 14:18:27 dnsmasq[1054]: read /tmp/mnt/sda1/adblocking/hosts-adblock - 388517 addresses
Mar  6 14:18:27 dnsmasq[1054]: using nameserver 127.0.0.1#65053
Mar  6 14:18:28 WAN Connection: Fail to connect with some issues.
Mar  6 14:18:28 stop_nat_rules: apply the redirect_rules!
Mar  6 14:18:30 pppd[515]: Connection terminated.
Mar  6 14:18:30 pppd[515]: Sent PADT
Mar  6 14:18:30 pppd[515]: Modem hangup
Mar  6 14:19:15 pppd[515]: Timeout waiting for PADO packets
Mar  6 14:20:30 pppd[515]: Timeout waiting for PADO packets
Mar  6 14:20:49 rc_service: httpd 446:notify_rc start_autodet
Mar  6 14:20:51 kernel: autodet uses obsolete (PF_INET,SOCK_PACKET)
Mar  6 14:21:45 pppd[515]: Timeout waiting for PADO packets
Mar  6 14:22:38 rc_service: httpd 446:notify_rc start_autodet
Mar  6 14:22:40 rc_service: httpd 446:notify_rc start_autodet
Mar  6 14:23:00 rc_service: httpd 446:notify_rc start_autodet
Mar  6 14:23:00 pppd[515]: Timeout waiting for PADO packets
Mar  6 14:23:01 pppd[515]: PPP session is 24093 (0x5e1d)
Mar  6 14:23:01 pppd[515]: Connected to 00:30:88:19:c3:bb via interface eth0
Mar  6 14:23:01 pppd[515]: Using interface ppp0
Mar  6 14:23:01 pppd[515]: Connect: ppp0 <--> eth0
Mar  6 14:23:02 rc_service: httpd 446:notify_rc start_autodet
Which model router?
Did you just flash to 380.57? If so, which version of firmware were you on prior to flashing? If not, did you alter anything, or was anything changed on your behalf, either at the ISP or the router?
And what's happening now?
five days ago i installed 380.58 alpha3 but udpxy for watching IPTV did not working and goes back to 380.57.....i did factory reset after flashing 380.57 and put settings and jffs from backup.....
router model is AC68U......is there a way to real hard reset the router and then i will manual step by step over setting.....
Can I suggest, assuming you haven't read it - or even if you have - you read Merlin's advice on "hard reset" i.e. restoring to factory default settings (and manually reconfiguring afterwards). http://www.snbforums.com/threads/faq-nvram-and-factory-default-reset.22822/
And can I also suggest L&LD's advice at http://www.snbforums.com/threads/no...l-and-manual-configuration.27115/#post-205573
I find that even if you're familiar with these posts, it still pays dividends to re-read them every so often.
i think when i set https in webui then i lost connection once or twice a day.....at the moment i have http and didn`t disconnected yet since two days....is possible bug when is https enabled?
still have problem with disconnect once a day every day for 5 minutes....is possible to solved this:
i did factory reset many times and manual setup but still nothing better.....
i deleted everything from jffs and usb and did factory reset and manualy setup again....now will test without usb stick and jffs scripts....i googled for this pppd disconnecting and lot of people have same problem.....i will be very happy if @Merlin look inside the firmware code and check why some people have this problem....with version 380.57 and earlier i didn`t have this problem....
It's ISP-specific, so there's nothing I can do (assuming the problem really lies in rp-pppoe, which I highly doubt).
Is possible someone write a script that will reconnect when pppd connection terminated?
sent from Kodi 17 Krypton
Won't help when the issue is with the modem or the ISP:
Looks like your modem stopped responding for 2 minutes. Make sure it's not your modem that's crashing and rebooting itself.
today i test merlin firmwares, 378.56_2, 380.57, 380.59 and latest 380.60_alpha3 but i got pppd disconnection on all firmwares....i change ISP modem and nothing better....i googled for that kind errors, disconnection but do not get any solution...maybe just @RMerlin can made some changes in asus firmware code for pppoe connection?
Are you in the UK with a Hub 3.0 modem? If so, it's a known problem with the modem (you can search for the details).
no, i am from slovenia, telekom slovenia with innbox v60u modem.....
i think i found my problem for disconnecting.....ppp0 create connection everytime to eth0 but eth0 is for IPTV....
i need to connect ppp0 < -- > ppp0
how to tell router to use this connection?
eth0 is the physical WAN port. ppp0 is a virtual interface on top of eth0, so this is perfectly normal.
but if i put line in putty "ifconfig" i see there configuration for IPTV for eth0....i think i have wrong route in my router but do not know what to do...
@RMerlin; I found the cause of my problem.I can confirm it is a firewall. yesterday i disabled it and no more pppd disconnection....I recommend you that look a little in the firewall area in the next versions....:)
Got a RT-N66U, brandnew and fresh flashed out of the box with Firmware 380.58. Did have a DD-WRT before which worked flawlessly so I can safely say those problems do not come from the Modem.
I can confirm the same issues. According to other tips I've disabled UPnP which did not help. Do still have several disconnects over the day, only about 15sec but still annoying.
Will now try disabling the firewall, hope this helps!
Jun 21 06:50:15 pppd[12766]: No response to 10 echo-requests
Jun 21 06:50:15 pppd[12766]: Serial link appears to be disconnected.
Jun 21 06:50:15 pppd[12766]: Connect time 100.4 minutes.
Jun 21 06:50:15 pppd[12766]: Sent 1653064 bytes, received 2572002 bytes.
Jun 21 06:50:15 dnsmasq[244]: read /etc/hosts - 5 addresses
Jun 21 06:50:15 dnsmasq[244]: using nameserver 212.202.xxx.1#53
Jun 21 06:50:15 dnsmasq[244]: using nameserver 212.202.xxx.2#53
Jun 21 06:50:18 WAN Connection: Fail to connect with some issues.
Jun 21 06:50:18 stop_nat_rules: apply the redirect_rules!
Jun 21 06:50:21 pppd[12766]: Connection terminated.
Jun 21 06:50:21 pppd[12766]: Sent PADT
Jun 21 06:50:21 pppd[12766]: Modem hangup
Jun 21 06:50:31 pppd[12766]: PPP session is 1927 (0x787)
Jun 21 06:50:31 pppd[12766]: Connected to 00:18:82:a9:33:xx via interface eth0
Jun 21 06:50:31 pppd[12766]: Using interface ppp0
Jun 21 06:50:31 pppd[12766]: Connect: ppp0 <--> eth0
Jun 21 06:50:34 pppd[12766]: Remote message: Authentication success,Welcome!
Jun 21 06:50:34 pppd[12766]: PAP authentication succeeded
Jun 21 06:50:34 pppd[12766]: peer from calling number 00:18:82:A9:33:xx authorized
Jun 21 06:50:34 pppd[12766]: local  IP address 87.234.xx.xxx
Jun 21 06:50:34 pppd[12766]: remote IP address 213.148.133.xxx
Jun 21 06:50:34 pppd[12766]: primary   DNS address 212.202.xxx.1
Jun 21 06:50:34 pppd[12766]: secondary DNS address 212.202.xxx.2
Jun 21 06:50:34 rc_service: ip-up 5857:notify_rc start_firewall
Jun 21 06:50:34 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Jun 21 06:50:34 dnsmasq[244]: read /etc/hosts - 5 addresses
Jun 21 06:50:34 dnsmasq[244]: using nameserver 212.202.xxx.1#53
Jun 21 06:50:34 dnsmasq[244]: using nameserver 212.202.xxx.2#53
Jun 21 06:50:34 wan: finish adding multi routes
Jun 21 06:50:34 rc_service: ip-up 5857:notify_rc stop_upnp
Jun 21 06:50:34 rc_service: ip-up 5857:notify_rc start_upnp
Jun 21 06:50:34 rc_service: waitting "stop_upnp" via ip-up ...
Jun 21 06:50:27 pppd[12766]: System time change detected.
Jun 21 06:50:27 WAN Connection: WAN was restored.
in your case you get connection back...in my case i didn`t....so now with disabled firewall i don`t have pppd disconnection yet....
Well, looks like is it not the firewall in my case... Really don't know what to do.
Jun 21 21:20:08 pppd[8402]: No response to 10 echo-requests
Jun 21 21:20:08 pppd[8402]: Serial link appears to be disconnected.
Jun 21 21:20:08 pppd[8402]: Connect time 420.2 minutes.
Jun 21 21:20:08 pppd[8402]: Sent 57687780 bytes, received 422862209 bytes.
Jun 21 21:20:08 miniupnpd[8441]: Failed to get IP for interface ppp0
Jun 21 21:20:08 miniupnpd[8441]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Jun 21 21:20:08 dnsmasq[244]: read /etc/hosts - 5 addresses
Jun 21 21:20:08 dnsmasq[244]: using nameserver 212.202.xxx.1#53
Jun 21 21:20:08 dnsmasq[244]: using nameserver 212.202.xxx.2#53
Jun 21 21:20:12 WAN Connection: Fail to connect with some issues.
Jun 21 21:20:12 stop_nat_rules: apply the redirect_rules!
Jun 21 21:20:14 pppd[8402]: Connection terminated.
Jun 21 21:20:14 pppd[8402]: Sent PADT
Jun 21 21:20:14 pppd[8402]: Modem hangup
Jun 21 21:20:24 pppd[8402]: PPP session is 29083 (0x719b)
Jun 21 21:20:24 pppd[8402]: Connected to 00:18:82:a9:33:xx via interface eth0
Jun 21 21:20:24 pppd[8402]: Using interface ppp0
Jun 21 21:20:24 pppd[8402]: Connect: ppp0 <--> eth0
Jun 21 21:20:27 pppd[8402]: Remote message: Authentication success,Welcome!
Jun 21 21:20:27 pppd[8402]: PAP authentication succeeded
Jun 21 21:20:27 pppd[8402]: peer from calling number 00:18:82:A9:33:xx authorized
Jun 21 21:20:27 miniupnpd[8441]: Failed to get IP for interface ppp0
Jun 21 21:20:27 miniupnpd[8441]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Jun 21 21:20:27 pppd[8402]: local  IP address 87.234.55.xxx
Jun 21 21:20:27 pppd[8402]: remote IP address 213.148.133.xxx
Jun 21 21:20:27 pppd[8402]: primary   DNS address 212.202.xxx.1
Jun 21 21:20:27 pppd[8402]: secondary DNS address 212.202.xxx.2
Jun 21 21:20:27 rc_service: ip-up 10865:notify_rc start_firewall
Jun 21 21:20:27 dnsmasq[244]: read /etc/hosts - 5 addresses
Jun 21 21:20:27 dnsmasq[244]: using nameserver 212.202.xxx.1#53
Jun 21 21:20:27 dnsmasq[244]: using nameserver 212.202.xxx.2#53
Jun 21 21:20:27 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Jun 21 21:20:27 wan: finish adding multi routes
Jun 21 21:20:27 rc_service: ip-up 10865:notify_rc stop_upnp
Jun 21 21:20:27 rc_service: ip-up 10865:notify_rc start_upnp
Jun 21 21:20:27 rc_service: waitting "stop_upnp" via ip-up ...
Jun 21 21:20:27 miniupnpd[8441]: shutting down MiniUPnPd
Jun 21 21:20:29 miniupnpd[10899]: HTTP listening on port 49978
Jun 21 21:20:29 miniupnpd[10899]: Listening for NAT-PMP/PCP traffic on port 5351
Jun 21 21:20:32 WAN Connection: WAN was restored.
