Quickster357
Update: Problem resolved! Read the last post. Also, you definitely need a MoCA filter with the PPC EVO amp. When tested, nodes will talk to each other through the incoming demarcation port.
Hello, I originally did not want to create an account and ask for help so I've been searching multiple forums and google, but to no avail I cannot figure out why my ECB6200's cannot "talk" to eachother when my ECB2500's were able to.
To start, we have Comcast internet, TV and phone (yes an eMTA/Modem/router AIO, but I shut down the router portion). Initially from the tap it was connected to a 3-way -3.5dB splitter rated at 1KHz. One went to the eMTA/Modem and the other connected to a SV-A15PRS 15dB amp to a MCR HP-208PV 8-way splitter rated at 5-3000MHz. My Moca 1.1 ECB2500's were able to connect fine (even through the amp!) also no PoE filter. Bad me. In any case, I purchased the ECB6200K02 package from B&H photo and video. They came with the most recent firmware 2.11.1.10 installed. I hooked them up in the same configuration as my ECB2500s. Sadly, the COAX light did not come on. Even after waiting for an hour.
After googling, I figured it was the amp that probably did not pass the 2.0 signal properly or the "bonded" signal. I then purchased a Holland PoE filter and a PPC Evo Entry 1-9-u/u amp from amazon, which is supposed to be MOCA friendly. I tested everything beforehand with the supplied short cables from the ECB6200K02 box. I also tried the amp un-powered and powered on.
ECB6200->coax in->ECB6200. Boom coax light.
Ok, next step. ECB6200->coax in->PPC EVO amp port 1->PPC EVO amp port 5->coax in->ECB6200. Works good.
Ok, next step (since one ECB6200 is going to be connected to the eMTA/Modem and router on the main floor). ECB6200->coax in->PPC Evo eMTA/Modem -3.5dB passive port->PPC Evo port 1->coax in->ECB6200. Worked just fine. Sweet. Time to install!
So I installed the new amp in my garage where the old Comcast SVI amp/8-way splitter was and hooked everything up according to http://www.ppc-online.com/docs/MKTimages/upload/Installation-Guide-9-port-Generic-2.pdf
I took note that "longer runs" (ie. in the basement where I have one of my ECB2500/ECB6200 going to be for better signal/whole house internet) should be on ports 1-4 and shorter runs 5-8 (so main level and upstairs). I have my other ECB2500/ECB6200 on the main floor where the eMTA/Modem is on the PASSIVE line and the other in the basement on port 2. My ECB6200 coax lights will not light up, but my ECB2500's will.
Am I missing something? Could it be the length of RG-6 coax between the modem->amp->basement? If so, why were my 1.1 devices working and not my 2.0? Can anyone help my dilemma?
PS. Sorry for the very long post.
UPDATE: All coax runs are RG-6 quad and the lengths from basement install to PPC Evo amp ~70ft-80ft and coax run from eMTA/Modem to PPC Evo amp ~35ft all point to point. No other junctions or splits.
*On a final note, eMTA/Modem->ECB6200->PPC Evo amp passive port->PPC Evo amp port 2->ECB2500 works!*
