N66U 3.0.0.4.374.39_0 - USB hubs/cardreaders still do not work
amigohd
As with the 3.0.0.4.374.38' versions my usb card readers connected to an usb hub do not work. If I go back to RT-N66U_3.0.0.4_374.35_4 it works without any modifications.
OScam errors:
2014/02/03 14:24:36 56E4C8 r sky [smartreader] usb bulk write failed : ret = -7
2014/02/03 14:24:36 56C7C8 r orf [smartreader] usb bulk write failed : ret = -7
2014/02/03 14:24:36 522E58 r srg [smartreader] usb bulk write failed : ret = -7
2014/02/03 14:24:46 56E4C8 r sky [smartreader] usb bulk write failed : ret = -7
2014/02/03 14:24:46 56C7C8 r orf [smartreader] usb bulk write failed : ret = -7
2014/02/03 14:24:46 522E58 r srg [smartreader] usb bulk write failed : ret = -7
2014/02/03 14:24:48 56E4C8 r sky [smartreader] Error activating card.
2014/02/03 14:24:48 56C7C8 r orf [smartreader] Error activating card.
2014/02/03 14:24:48 522E58 r srg [smartreader] Error activating card.
2014/02/03 14:24:49 56E4C8 r sky [smartreader] init card at 369 mhz
2014/02/03 14:24:49 56C7C8 r orf [smartreader] init card at 369 mhz
2014/02/03 14:24:49 522E58 r srg [smartreader] init card at 369 mhz
2014/02/03 14:24:59 56E4C8 r sky [smartreader] usb bulk write failed : ret = -7
2014/02/03 14:24:59 56C7C8 r orf [smartreader] usb bulk write failed : ret = -7
2014/02/03 14:24:59 522E58 r srg [smartreader] usb bulk write failed : ret = -7
lsusb:
admin@router:/tmp/home/root# lsusb
Bus 001 Device 009: ID 0403:6001
Bus 001 Device 008: ID 0403:6001
Bus 001 Device 007: ID 0403:6001
Bus 001 Device 006: ID 05e3:0608
Bus 001 Device 005: ID 058f:6366
Bus 001 Device 004: ID 0718:0618
Bus 001 Device 003: ID 05e3:0608
Bus 001 Device 002: ID 058f:6254
Bus 002 Device 001: ID 1d6b:0001
Bus 001 Device 001: ID 1d6b:0002
dmesg:
option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
option 1-1.1.3.4:1.0: device disconnected
option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
option 1-1.1.4:1.0: device disconnected
option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
option 1-1.1.3.1:1.0: device disconnected
my argolis smargo smartreader are recognized as modems?
still the new builds, as the .38 previous do have some failures. 3.0.0.4_374.35_4 do recognize my cardreaders properly.
this is the correct output on 3.0.0.4_374.35_4 of dmesg.
dmesg:
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usbcore: registered new interface driver usblp
drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
usbcore: registered new interface driver asix
usb 1-1: new high speed USB device using ehci_hcd and address 2
usb 1-1: configuration #1 chosen from 1 choice
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver rndis_host
usbcore: registered new interface driver zaurus
usb 1-1.1: new high speed USB device using ehci_hcd and address 3
and all this is missing in .38 and .39 builds. I guess some core usb modifications on the kernel.
Nobody using usb hubs? Nobody having problems?
The two hard disks I tested with my old USB hub worked fine.
Results will vary depending on the HUB used and which devices you connect to it most likely.
Make sure it's a powered hub. A self-powered one might not provide enough power to work reliably.
well, the hub is powered. it does work anywhere else. and it does work with previous builds I mentioned. So there has to be a big change in the kernel code since the .38 release as with the .35_4 it still works like a charm.
