NAS (any brand) external USB drive bay - issues.
In my case, Synology DS212.
I just bought a $45 nice steel box 2 drive bay box. Has USB3 connector.
The chip inside is a Prolific USB3 to SATA bridge. It has these switch-selected modes:
Set for RAID0 (box's role is backup the NAS excluding big image backups of PCs).
Plug the external box into DS212's USB2 port. Comes up as a 3.8TB drive. Perfect.
Move the plug to the USB3 port on the DS212. wait, wait. Nothing recognized.
I thought the bridge chip in the box made it transparent to the host (NAS) as to which of the above four settings was in use. NAS would not be RAID-aware for this box.
I filed a ticket with Synology and explained as above: works on USB2, not on USB3.
Response was a mistaken "Synology DSM (OS) does not support RAID on external drives).
I countered with: Works on USB2. Not USB3. Box makes it transparent to the NAS.
So I use USB2 and it works just fine. At 20Mbytes/sec. Drives are formatted ext4 by NAS OS (DSM), with switches set to RAID0. NAS sees 3.8TB. On USB2 only.
It also doesn't work with a one-drive enclosure, USB3 and some or all USB3 hubs. Drive enclosure works fine USB3 if a hub is not introduced.
Any ideas? I think the USB3 hardware in the circa 2012 NAS is at fault. Probably using 2011 or older USB3 chips. Hardware or Linux USB3 drivers at fault? Both? Any other 4 year old USB3 NAS work correctly with an external USB3 hub?
- NORMAL - just a USB hub so the host sees 2 drives
- JBOD - host sees one drive (volume?), size is sum of two drives
- RAID0 (striped) - host sees one drive, size is sum of two drives
- RAID1 (mirrored) - host sees one drive, size is smaller of two drives
