I am having a weird issue openVPN, please someone help.
In short, VPN server works just after being turned on, but on reboot nothing works anymore.
These are the details:
I am trying to set up a VPN server on my RT AC3200 with merlin 384.13_8
Attached is my booting log (slightly edited for privacy), including detailed VPN server log information. For what is worth, when pinging from my local wan, just after booting, works until approximately the following line:
Jul 20 21:59:45 rc_service: waitting "restart_diskmon" via ntpd_synced ...
After that, I receive a “Destination net unreachable” message.
- Just after I set the VPN on, everything is OK. The VPN works and I can establish a VPN connection coming from WAN. I can also surf the internet when connected to my local network.
- However, if I reboot the router, I loose internet access when connected from my local network (ping returns destination net unreachable), and I cannot connect to the VPN from WAN.
I can still login to my router from LAN and I can ping with the router tools. - If I disable the VPN server, internet connection still doesn´t work. I need to disable the VPN server and reboot the router to have internet connection from my local lan.
