RT-AC5300: No 5 GHz radio
ahmetoz27
Hello guys, i have with RT-AC5300 modem 5GHZ doesnt work and light is off, i tried everything but cant solve the issue 2.4 ghz works normal. Can anyone help and guide me please.
I have the same problem 5.0 GHZ turned on in but The MAC address of 5GHz-1 and 5GHz-2 is empty. I cant find any solution...
Perhaps your router decided to retire. In this case your only solution is a new router.
I have installed now Freshtomato but cannot see any 5ghz settings here but in command like looks like ther is 5ghz.
XML:
FreshTomato Web Shell ready.
size: 56380 bytes (74692 left)
 Welcome to the Asus RT-AC5300 [FreshTomato]
 Date: Thu Jan 1 1970
 Time: 01:12:38 up 12 min
 Load average: 0.00, 0.03, 0.04
 Mem usage: 5.7 (used 28.65 of 503.18 MB)
 LAN1: 192.168.1.1/24 @ DHCP: 192.168.1.2 - 192.168.1.50
 WL0 : 2.4GHz @ Asus @ channel: 13 @ 9C:5C:8E:4B:DE:90        THIS IS WORKING
 WL1 : 5GHz @ Asus @ channel: 36 @ 9C:5C:8E:4B:DE:94                         NOT WORKING
 WL2 : 5GHz @ Asus @ channel: 100 @ 9C:5C:8E:4B:DE:98                         NOT WORKING
If the router's hardware is defective firmware change won't help.
if you cant see the MAC ID in the setup page, then the radio has gone kaput. I also have a RT-AC5300 where the high band 5ghz radio is gone. It is hardware issue and nothing will bring it back ...
You can throw it away and buy a new All-In-One home router or you can use it as a Wired Router with radios disabled and antennas removed feeding an Access Point. This is the most cost-effective solution. Something like EAP245v3 is about $90 and comes with PoE injector. This RT-AC5300 router has older hardware, no firmware update for >1 year and seems like it's in unofficial End-of-Life state. It will never receive 388 firmware either. If only one Access Point (AIO router) is needed for your place I personally would buy an new AIO router, but not an overpriced tri-band spider model. More like compact size and much newer and faster hardware RT-AX86S. It's about $140 on sale. I don't know what country you live in though and what your local market is.
