[Beta] RT-AC87U_3.0.0.4_378_8248 Unofficial Beta
I wonder if my device has developed a fault. I'll try this new firmware and, failing that, go back to the stock firmware the router came with to check if it's still happening. I'll also look at some active cooling, perhaps the 5GHz ends up overheating or something (is it possible to monitor temperatures with these firmwares?).
So far I've found a GUI issue when I select "AiCloud" Tab, it shows "USB Application" as selected instead, so I need to go to another tab in order to access "USB Application" one.
Well, and WPS issue is still present
Hi Sentinelxdx,
They are working on it.
Hi Sentinelxdx,
In _8258 is not fixed either. I already reported it too.
Does _8248 comes with Feedback tab?
Replied through Tapatalk
So, the port teaming also doesn't work yet? Damn, i just ordered a ds215+ NAS
It's probably coming however, I see some code related to it was added in a recent GPL release.
Going to try in a few days to see if it keeps disconnecting on 5ghz. Did anyone stop disconnecting after upgrading?
Regarding the basic stability of the 5GHz band (meaning without MU-MIMO and beamforming): I have to say that there are no hardware issues which should prevent a flawless function. As far as I was able to observe this over all these months, the connection issues are restricted to mobile devices and related devices (quasi-embedded, smart, etc. devices and those based on mobile OS'es, like set top boxes).
All of my regular computers which include Windows boxes with 5GHz and ARM Chromebook, also with 5GHz, are rock solid, with no connection drops at all. When it comes to the Windows machine e.g. I know that the connection is flawlessly perfect, as I need to use that for work - so what I'm getting is a 100% uninterrupted connection, via VPN over a whole 8 or 9hr work day - otherwise I'd see any connection drops instantly in the VPN client's logs and notifications.
So, as far as I know those problems are mostly related to mobile device's adapter's going into sleep mode while being connected to the RT-AC87, otherwise the non-Beamforming 5GHz is already quite stable for non-Apple users.
i am interested in your opinion, because I have been plagued by 5G issue. have you tried to make regular computer into sleep, if there will be connectivity issue? about 87u's 5G issue, i even have been suspected to be hardware flaw, rather than firmware issue. but I saw something in this forum seem to can overthrow my doubt, so confused......
at present, it seems that most of the complaints about the 5G issue is from apple device users. i was thinking, maybe this problem can not be solved by asus/quantenna, maybe they need apple's help, but this seems ridiculous.
Any of you tested the VPN client section using OpenVPN and .ovpn configuration files? I cannot get it to work... it seems to connect fine but no internet connection on client machines....
Aug 26 19:52:09 rc_service: httpd 2260:notify_rc restart_vpncall
Aug 26 19:52:11 openvpn[3183]: DEPRECATED OPTION: --tls-remote, please update your configuration
Aug 26 19:52:11 openvpn[3183]: OpenVPN 2.3.2 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [eurephia] [MH] [IPv6] built on Aug 21 2015
Aug 26 19:52:11 openvpn[3183]: Deprecated TLS cipher name 'DHE-RSA-AES256-SHA', please use IANA name 'TLS-DHE-RSA-WITH-AES-256-CBC-SHA'
Aug 26 19:52:11 openvpn[3183]: Deprecated TLS cipher name 'DHE-DSS-AES256-SHA', please use IANA name 'TLS-DHE-DSS-WITH-AES-256-CBC-SHA'
Aug 26 19:52:11 openvpn[3183]: Deprecated TLS cipher name 'AES256-SHA', please use IANA name 'TLS-RSA-WITH-AES-256-CBC-SHA'
Aug 26 19:52:11 openvpn[3183]: Socket Buffers: R=[122880->131072] S=[122880->131072]
Aug 26 19:52:11 openvpn[3188]: UDPv4 link local: [undef]
Aug 26 19:52:11 openvpn[3188]: UDPv4 link remote: [AF_INET]209.99.63.150:443
Aug 26 19:52:11 openvpn[3188]: TLS: Initial packet from [AF_INET]209.99.63.150:443, sid=533e106b 15d8777e
Aug 26 19:52:11 openvpn[3188]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Aug 26 19:52:12 openvpn[3188]: VERIFY OK: depth=1, /C=KY/ST=GrandCayman/L=GeorgeTown/O=GoldenFrog-Inc/CN=GoldenFrog-Inc_CA/emailAddress=admin@goldenfrog.com
Aug 26 19:52:12 openvpn[3188]: VERIFY X509NAME OK: /C=KY/ST=GrandCayman/L=GeorgeTown/O=GoldenFrog-Inc/OU=On_Demand/CN=us5.vyprvpn.com/emailAddress=admin@goldenfrog.com
Aug 26 19:52:12 openvpn[3188]: VERIFY OK: depth=0, /C=KY/ST=GrandCayman/L=GeorgeTown/O=GoldenFrog-Inc/OU=On_Demand/CN=us5.vyprvpn.com/emailAddress=admin@goldenfrog.com
Aug 26 19:52:13 openvpn[3188]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Aug 26 19:52:13 openvpn[3188]: Data Channel Encrypt: Using 256 bit message hash 'SHA256' for HMAC authentication
Aug 26 19:52:13 openvpn[3188]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Aug 26 19:52:13 openvpn[3188]: Data Channel Decrypt: Using 256 bit message hash 'SHA256' for HMAC authentication
Aug 26 19:52:13 openvpn[3188]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Aug 26 19:52:13 openvpn[3188]: [us5.vyprvpn.com] Peer Connection Initiated with [AF_INET]209.99.63.150:443
Aug 26 19:52:15 openvpn[3188]: SENT CONTROL [us5.vyprvpn.com]: 'PUSH_REQUEST' (status=1)
Aug 26 19:52:16 openvpn[3188]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.3.150.1,explicit-exit-notify 5,rcvbuf 262144,route-gateway 10.3.150.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.3.150.207 255.255.255.0'
Aug 26 19:52:16 openvpn[3188]: OPTIONS IMPORT: timers and/or timeouts modified
Aug 26 19:52:16 openvpn[3188]: OPTIONS IMPORT: explicit notify parm(s) modified
Aug 26 19:52:16 openvpn[3188]: OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
Aug 26 19:52:16 openvpn[3188]: Socket Buffers: R=[131072->245760] S=[131072->131072]
Aug 26 19:52:16 openvpn[3188]: OPTIONS IMPORT: --ifconfig/up options modified
Aug 26 19:52:16 openvpn[3188]: OPTIONS IMPORT: route options modified
Aug 26 19:52:16 openvpn[3188]: OPTIONS IMPORT: route-related options modified
Aug 26 19:52:16 openvpn[3188]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Aug 26 19:52:16 openvpn[3188]: TUN/TAP device tun15 opened
Aug 26 19:52:16 openvpn[3188]: TUN/TAP TX queue length set to 100
Aug 26 19:52:16 openvpn[3188]: do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Aug 26 19:52:16 openvpn[3188]: /sbin/ifconfig tun15 10.3.150.207 netmask 255.255.255.0 mtu 1500 broadcast 10.3.150.255
Aug 26 19:52:16 openvpn[3188]: /sbin/route add -net 209.99.63.150 netmask 255.255.255.255 gw 109.132.128.1
Aug 26 19:52:16 openvpn[3188]: /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.3.150.1
Aug 26 19:52:16 openvpn[3188]: /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.3.150.1
Aug 26 19:52:16 openvpn[3188]: Initialization Sequence Completed
Can someone report this guest network bug to asus, please:
If setting up a time limited guest network (eg 16 hours) the gui shows occasionally "< 1 Minuten" afterwards. nevertheless it´ll never get´s disabled.
Have you tried to chnage to English to doublecheck is not just an issue with the localised language?
