While I was trying to program the permitted IP ranges into the camera remotely, I entered the 3 sets of ranges in the wrong sequence and ended up locking myself out after the1st set, requiring a factory reset of the camera.
Good thing I had the configuration settings saved from 2 months ago to load, or it would be a real pain trying to reconfigure all the motion-detection region, IR sensitivity, storage, event triggers, etc options the same way.
While dismounting the camera, the antenna housing had become so brittle (exposed to sun over time) that it crumbled:
So now I use a segment of a big straw to house the antenna and it may not be as weather-resistant as before.
Turns out that it was a Cloud camera. Their "cloud" service (which I forgot about) for this model has no storage option, so it is more of a live online/internet view option. I disabled it and just use local recording (to internal SD card, that gets transferred to my PC almost immediately in case the camera gets stolen) with a local wifi viewer.
Anyway, I have a working outdoor security camera that is a little less weather-resistant now, the ports are still open via UPnP (not sure what is doing it), but nothing bad can connect at those ports because of the programmed IP ranges.
Sent using Tapatalk
