RT-AC88u jffs mount problem Merlin Firmware.
Darrin Reed
I have been trying to install entware on merlin v380.57 firmware on my new router, but keep on getting no such dir or file. So I decided to reformat the jffs using the option in administration, but when the router is rebooted properly, under tools it shows jffs unmounted. I have tried rebooting and searching on the net for mounting commands to no aval. My traffic analysis is broken and when I tried to switch it on, it exits out of the router for a relogin.
Can someone help me remount the jffs partition as it has crippled my router in various functions. Tried for two days now. Even on asus official firmware traffic analysis is broken. I really want it back.
Thanks in advance.
Thanks in advance.
I am new to these forums and have serious issues with my router after trying entware.
My router jumps me out of any changes that I make. Also the traffic analyser does the same thing with 0 clients. Completely blank. I dont know how I can get out of this problem without binning this router. Even on official firmware it does the same thing.
Ps: I have searched the forums to no aval.
Try using the routers IP address rather than its name. It would often throw me back to the login screen if I used its dns name e.g. router, asusrouter.
Also try to reset to factory defaults.
Try the alpha firmware and go back to factory defaults. 380.58
entware works for me on usb. I haven't tried on jffs.
yes I have that firmware on my router now. Have factory defaults set. Still the same problem. I think without the jffs mounted the router cant write traffic analysis data or other stuff to it, so it kicks you out to resign in again. Even with official firmware I have the same problem. The jffs in locked for some reason. I dont know how to unlock it. I have tried rebooting, emergency mode. mini server mode. Every firmware available for the router I have loaded, same result.
I am at a loss.
I am at a loss.
Have you tried post 3?
I have already done that. What I need is a jffs mount command. I think the nvram is off limits to the os. I have flashed and factory defaulted on all available firmware. I am pulling my hair out on this. My rt-ac68u is running fine, with entware and transmission to boot. I was hoping the same for the rt-ac88u.
Try this via telnet/ssh.....
nvram set jffs2_enable=0
nvram set jffs2_format=0
nvram commit
reboot
after the reboot completes
nvram set jffs2_enable=1
nvram set jffs2_format=1
nvram commit
reboot
nvram commit
reboot
nvram commit
reboot
Thank you for this but it is still the same.
Had the same issue . Try WPS reset
I tried that. It is the wps button that puts it into a fast flash mode. The reset button puts it into a slow flash mode. I am afraid that that didnt work either. sigh!
One thing that I have noticed is that the nvram usage is getting greater with every reset and format. Very strange. If I could really force to wipe it, it might come ok as all reset and wps methods have failed.
Does anyone know of a forced wipe command for nvram. ?. ....
I see you are still using router.asus.com. Try the IP address e.g. 192.168.x.x
The firmware will often randomly kick you out unless you do so.
What does the system log says about JFFS2 at boot time?
Feb 5 08:58:37 transmission-daemon[2998]: UDP Please add the line "net.core.wmem_max = 1048576" to /etc/sysctl.conf (tr-udp.c:94)
Feb 5 08:58:37 transmission-daemon[2998]: DHT Generating new id (tr-dht.c:310)
Feb 5 08:58:37 transmission-daemon[2998]: Using settings from "/tmp/mnt/sdb1/Download2/config" (daemon.c:699)
Feb 5 08:58:37 transmission-daemon[2998]: Saved "/tmp/mnt/sdb1/Download2/config/settings.json" (variant.c:1217)
Feb 5 08:58:37 transmission-daemon[2998]: Loaded 8 torrents (session.c:2007)
Feb 5 08:58:37 transmission-daemon[2998]: Port Forwarding (NAT-PMP) initnatpmp succeeded (0) (natpmp.c:73)
Feb 5 08:58:37 transmission-daemon[2998]: Port Forwarding (NAT-PMP) sendpublicaddressrequest succeeded (2) (natpmp.c:73)
Feb 5 08:58:45 transmission-daemon[2998]: Port Forwarding State changed from "Not forwarded" to "Starting" (port-forwarding.c:95)
Feb 5 08:58:45 transmission-daemon[2998]: Port Forwarding State changed from "Starting" to "???" (port-forwarding.c:95)
Feb 5 08:58:46 dmreed: sh /opt/S95transmission.1 start
Feb 5 08:58:48 rc_service: hotplug 965:notify_rc start_cloudsync 0
Feb 5 08:58:48 rc_service: hotplug 965:notify_rc restart_nasapps
Feb 5 08:58:48 rc_service: waitting "start_cloudsync 0" via hotplug ...
Feb 5 08:58:48 Cloudsync client: daemon is started
Feb 5 08:58:48 dropbox client: daemon is started
Feb 5 08:58:49 iTunes: daemon is stopped
Feb 5 08:58:49 FTP Server: daemon is stopped
Feb 5 08:58:50 Samba Server: smb daemon is stopped
Feb 5 08:58:50 kernel: gro disabled
Feb 5 08:58:50 Timemachine: daemon is stopped
Feb 5 08:58:50 kernel: gro enabled with interval 2
Feb 5 08:58:52 Samba Server: daemon is started
Feb 5 08:58:52 FTP server: daemon is started
Feb 5 08:58:52 mt-daapd[3168]: Starting signal handler
Feb 5 08:58:52 iTunes Server: daemon is started
Feb 5 08:58:53 mt-daapd[3168]: Loading playlists
Feb 5 08:58:53 mt-daapd[3168]: Initializing database
Feb 5 08:58:53 mt-daapd[3168]: Starting mp3 scan
Feb 5 08:59:13 mt-daapd[3168]: Starting web server from /rom/etc/web on port 3689
Feb 5 08:59:13 mt-daapd[3168]: Could not open port: Address already in use
Feb 5 08:59:13 mt-daapd[3168]: Error staring web server: Address already in use
Feb 5 08:59:13 mt-daapd[3168]: Aborting
Feb 5 08:59:24 rc_service: rc 3348:notify_rc restart_wrs
Feb 5 08:59:26 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Feb 5 08:59:28 dmreed: sh /opt/S50asuslighttpd.1 firewall-start
Feb 5 08:59:28 dmreed: sh /opt/S50downloadmaster.1 firewall-start
Feb 5 08:59:29 dmreed: sh /opt/S95transmission.1 firewall-start
Feb 5 09:00:15 disk_monitor: Got SIGALRM...
Feb 5 09:30:10 sd-idle-2.6[401]: spinning down /dev/sdb
Feb 5 09:30:41 sd-idle-2.6[401]: spinning up /dev/sdb after 31 secs
Feb 5 09:43:11 sd-idle-2.6[401]: spinning down /dev/sda
Feb 5 09:50:41 sd-idle-2.6[401]: spinning down /dev/sdb after 20 mins
Feb 5 09:51:12 sd-idle-2.6[401]: spinning up /dev/sdb after 31 secs
Feb 5 09:58:12 sd-idle-2.6[401]: spinning up /dev/sda after 15 mins 1 secs
Feb 5 10:04:12 sd-idle-2.6[401]: spinning down /dev/sda after 6 mins
Feb 5 10:11:12 sd-idle-2.6[401]: spinning down /dev/sdb after 20 mins
Feb 5 10:11:43 sd-idle-2.6[401]: spinning up /dev/sdb after 31 secs
Feb 5 10:17:13 sd-idle-2.6[401]: spinning up /dev/sda after 13 mins 1 secs
Feb 5 10:22:13 sd-idle-2.6[401]: spinning down /dev/sda after 5 mins
Feb 5 10:36:43 sd-idle-2.6[401]: spinning down /dev/sdb after 25 mins
Feb 5 10:37:14 sd-idle-2.6[401]: spinning up /dev/sdb after 31 secs
Feb 5 10:56:44 sd-idle-2.6[401]: spinning up /dev/sda after 34 mins 31 secs
Feb 5 10:57:14 sd-idle-2.6[401]: spinning down /dev/sdb after 20 mins
Feb 5 10:57:45 sd-idle-2.6[401]: spinning up /dev/sdb after 31 secs
Feb 5 11:04:15 sd-idle-2.6[401]: spinning down /dev/sda after 7 mins 31 secs
Feb 5 11:17:45 sd-idle-2.6[401]: spinning down /dev/sdb after 20 mins
Feb 5 11:18:16 sd-idle-2.6[401]: spinning up /dev/sdb after 31 secs
Feb 5 11:35:46 sd-idle-2.6[401]: spinning up /dev/sda after 31 mins 31 secs
Feb 5 11:41:16 sd-idle-2.6[401]: spinning down /dev/sda after 5 mins 30 secs
Feb 5 11:43:16 sd-idle-2.6[401]: spinning down /dev/sdb after 25 mins
Feb 5 11:43:47 sd-idle-2.6[401]: spinning up /dev/sdb after 31 secs
Feb 5 11:58:17 sd-idle-2.6[401]: spinning up /dev/sda after 17 mins 1 secs
Feb 5 12:04:17 sd-idle-2.6[401]: spinning down /dev/sda after 6 mins
Feb 5 12:08:47 sd-idle-2.6[401]: spinning down /dev/sdb after 25 mins
Feb 5 12:09:18 sd-idle-2.6[401]: spinning up /dev/sdb after 31 secs
Feb 5 12:15:18 sd-idle-2.6[401]: spinning up /dev/sda after 11 mins 1 secs
Feb 5 12:20:48 sd-idle-2.6[401]: spinning down /dev/sda after 5 mins 30 secs
Feb 5 12:34:18 sd-idle-2.6[401]: spinning down /dev/sdb after 25 mins
Feb 5 12:34:49 sd-idle-2.6[401]: spinning up /dev/sdb after 31 secs
Feb 5 12:49:41 rc_service: httpd 491:notify_rc start_autodet
Feb 5 12:49:42 kernel: autodet uses obsolete (PF_INET,SOCK_PACKET)
Feb 5 12:54:49 sd-idle-2.6[401]: spinning up /dev/sda after 34 mins 1 secs
Feb 5 12:54:49 sd-idle-2.6[401]: spinning down /dev/sdb after 20 mins
Feb 5 12:55:20 sd-idle-2.6[401]: spinning up /dev/sdb after 31 secs
Feb 5 13:04:20 sd-idle-2.6[401]: spinning down /dev/sda after 9 mins 31 secs
Feb 5 13:15:20 sd-idle-2.6[401]: spinning down /dev/sdb after 20 mins
Feb 5 13:15:51 sd-idle-2.6[401]: spinning up /dev/sdb after 31 secs
Sorry for the long posts as all I had to do was upload a saved copy of my sys log from the router.
Ps: Entware and Optware could not be installed.
  • syslog.txt
Try to rescue the router with asus tool and latest asus fw then flash merlins and reset
