JumpShot20
I just received my N66U on Friday and have been putting it through its paces all weekend. While I've seen great range and throughput on 2.4ghz, I've seen extremely poor range and only intermittent signal on 5ghz.
Take a look at the image I've attached from inSSIDer. The blue line represents my 5ghz signal from my recliner which is a short hallway and one room away from my router. I did not move the entire time it was recording. You can see the signal come and go multiple times. Can anyone explain what might be causing this? Here are my settings on the 5ghz radio:
Firmware Version: 3.0.0.3.102
Wireless Mode: N Only
Control Channel: Auto
Channel Bandwidth: 40mhz
Extension Channel: Auto
Authentication Method: WPA2-Personal
WPA Encryption: AES
Network Key Rotation Interval: 0
TX Power Adjustment: 80
If anyone is able to provide any guidance, I would truly appreciate it. I've read these forums for a long time, but this is the first time I've needed to post. Thank you in advance.
WPA Encryption: AES
