Sanya IV Litvyak
Let me just begin by saying that I'm not sure that this thread is in the right board, I hope it is.
So to the problem, "I" recently upgraded my network from 100/10 to 500/50 and with that upgrade I got a new cable modem. Just by plugging my computer into the new modem and running a speed test I get the advertised speed of 500/50 (roughly, measured in Mb/s) but when I try through the Asus router (Modem in bridge mode) I get around 230-260 Mb/s down and 50 Mb/s up and looking at that download it's almost half of what I should be getting.
I'm using Asuswrt-merlin version 378.53
When looking at the routers network map page I can see that the CPUs Core 1 is using ~99% when downloading in ~250 Mb/s .. So am I right in assuming that this is a CPU bottleneck issue? And beyond that, what is the point of Gb/s Ethernet ports if they can't be used with those speeds because of CPU restraints? (if that is the case) =/
Is there any kind of optimization I can do in the settings to make it work better?
I do have DNSCrypt set up in the router.
(Using Cat 5e and Cat 6 cables)
Regards,
Sanya IV Litvyak
Regards,
Sanya IV Litvyak
