yorgi
We would like to get your help to see if you get faster then 50mbps running a VPN client with PIA service provider.
If you are using any other VPN provider your input is also welcome
Please post your speed tests and let us know;
-VPN service provider
-what part of the country you are from,
-Mbps of your ISP connection
-Which router model you are using
-what encryption you are using
-what were the fastest speeds you recorded when doing a speed test with your VPN client.
These test can help determine if VPN providers are throttling their bandwidth or if routers have hardware limitations.
thanks
thanks
