Martin - SNBuser
Hi all,
I would like to please ask for a little help with iptables, to setup fwknopd on my Asus-(Merlin rom) RT-AC87U with entware. My situation is that I can ssh into the router from the internal network. If I do a port scan from outside, everything is "stealth" - fine so far, so good...
Now, I would like to change this - to be able to ssh into my router, from outside. I believe I can use guides such as http://www.cipherdyne.org/fwknop/docs/fwknop-tutorial.html#quick-start but I have some questions and my most severe problem is that I don't understand why my iptables rules look like they do:
Why are the all these rules above? Why is it necessary with all these lines? I don't understand all these rules - somebody, please help if you know why or what all these rules do. I believe these are setup by Asus/Merlin, maybe based on my selections there, so I'm a little afraid of changing them (in any case, I would like to understand, thanks)...
I assume I should not enable ssh from the Asus-Merlin webgui, but let the fwknop-daemon temporarily handle the modification to iptables, for port 22, is that correct?
Next, I tried to to follow this guide https://help.ubuntu.com/community/SinglePacketAuthorization and it was easy to generate a key on my local pc using the command "gpg --gen-key". But then I had to do
"Generate Server-side GnuPG key pairs" and I discovered gpg is not available in my router, not even with entware which otherwise have so many packages, that this surprised me a little? It means, I cannot use GPG-keys, I think (if you know a way, please let me know). Instead of the GPG-method, I decided to use this method https://www.cipherdyne.org/fwknop/docs/fwknop-tutorial.html and on the client pc I wrote (yes, I wanted/would like to expose the SSH-server to port 443 instead of port 22, because port 443 is also used by HTTPS so I'm sure it'll work many places where there could be restrictions to port 22, the normal ssh port):
I'm not sure what the "save-rc-stanza" does (tried to read about it, didn't understand it), but now I have KEY_BASE64 and HMAC_KEY_BASE64, which I inserted (using copy/paste) in the bottom of the /opt/etc/fwknop/access.conf file on the Asus RT-AC87U-router. According to this the instructions here https://www.cipherdyne.org/fwknop/docs/fwknop-tutorial.html I should now be able to start the fwknop-daemon. I did it like this (please watch the output errors, this is beginning to exceed my skills, I would really appreciate a little help/comments here, notice after a short while I begin to press CTRL+C --> ^C^C^C^C^C ):
Please help - what is the problem here? How to continue from here? How to eliminate these errors and problems, so I can continue to the next step (must open port 443 + I must send an SPA packet from outside and test)...
I really appreciate any help/advice/ideas, thanks!
# iptables -L -n
Chain INPUT (policy ACCEPT)
target prot opt source destination
DROP icmp -- 0.0.0.0/0 0.0.0.0/0 icmptype 8
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0 state RELATED,ESTABLISHED
DROP all -- 0.0.0.0/0 0.0.0.0/0 state INVALID
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0 state NEW
ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp spt:67 dpt:68
ACCEPT icmp -- 0.0.0.0/0 0.0.0.0/0 icmp !type 8
Chain FORWARD (policy DROP)
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0 ctstate DNAT
Chain OUTPUT (policy ACCEPT)
Chain FUPNP (0 references)
Chain PControls (0 references)
Chain SECURITY (0 references)
RETURN tcp -- 0.0.0.0/0 0.0.0.0/0 tcpflags: 0x17/0x02 limit: avg 1/sec burst 5
DROP tcp -- 0.0.0.0/0 0.0.0.0/0 tcpflags: 0x17/0x02
RETURN tcp -- 0.0.0.0/0 0.0.0.0/0 tcpflags: 0x17/0x04 limit: avg 1/sec burst 5
DROP tcp -- 0.0.0.0/0 0.0.0.0/0 tcpflags: 0x17/0x04
RETURN icmp -- 0.0.0.0/0 0.0.0.0/0 icmptype 8 limit: avg 1/sec burst 5
RETURN all -- 0.0.0.0/0 0.0.0.0/0
Chain logaccept (0 references)
LOG all -- 0.0.0.0/0 0.0.0.0/0 state NEW LOG flags 7 level 4 prefix "ACCEPT "
Chain logdrop (0 references)
LOG all -- 0.0.0.0/0 0.0.0.0/0 state NEW LOG flags 7 level 4 prefix "DROP "
fwknop -A tcp/443 -D (my-external-IP: X.X.X.X) --key-gen --use-hmac --save-rc-stanza
@router:/tmp/mnt/sda/entware/etc/fwknop# fwknopd -fv
Opened access file: /opt/etc/fwknop/access.conf
Initialize access stanzas
Warning: REQUIRE_SOURCE_ADDRESS not enabled for access stanza source: 'ANY'
[+] Writing my PID (2653) to the lock file: /opt/var/fwknop/fwknopd.pid
Starting fwknopd
Using Digest Cache: '/opt/var/fwknop/digest.cache' (entry count = 0)
ipt_chk_support() CMD: '/opt/sbin/iptables -t filter -I INPUT 1 -s 127.0.0.2 -p udp -j ACCEPT' (res: 16, err: run_extcmd(): could not fdopen() pipe output file descriptor.
ipt_chk_support() CMD: '/opt/sbin/iptables -t filter -I INPUT 1 -s 127.0.0.2 -p udp -j ACCEPT' (res: -7, err: ))
ipt_chk_support() CMD: '/opt/sbin/iptables -t filter -C INPUT -s 127.0.0.2 -p udp -j ACCEPT' (res: 16, err: run_extcmd(): could not fdopen() pipe output file descriptor.
ipt_chk_support() CMD: '/opt/sbin/iptables -t filter -C INPUT -s 127.0.0.2 -p udp -j ACCEPT' (res: -7, err: )
ipt_chk_support() -C supported)
rule_exists_chk_support() CMD: '/opt/sbin/iptables -C INPUT -t filter -j FWKNOP_INPUT' (res: 16, err: run_extcmd(): could not fdopen() pipe output file descriptor.
rule_exists_chk_support() CMD: '/opt/sbin/iptables -C INPUT -t filter -j FWKNOP_INPUT' (res: -7, err: )
rule_exists_chk_support() Rule : '-t filter -j FWKNOP_INPUT' in INPUT already exists)
jump_rule_exists_chk_support() jump rule found
delete_all_chains() CMD: '/opt/sbin/iptables -t filter -D INPUT -j FWKNOP_INPUT' (res: 16, err: run_extcmd(): could not fdopen() pipe output file descriptor.
delete_all_chains() CMD: '/opt/sbin/iptables -t filter -D INPUT -j FWKNOP_INPUT' (res: -7, err: ))
delete_all_chains() Error 16 from cmd:'/opt/sbin/iptables -t filter -D INPUT -j FWKNOP_INPUT': run_extcmd(): could not fdopen() pipe output file descriptor.
^C^C^C^C^Cdelete_all_chains() CMD: '/opt/sbin/iptables -t filter -D INPUT -j FWKNOP_INPUT' (res: 16, err: run_extcmd(): could not fdopen() pipe output file descriptor.
.... etc etc...
.... etc etc...
delete_all_chains() CMD: '/opt/sbin/iptables -t filter -F FWKNOP_INPUT' (res: -7, err: )
delete_all_chains() Error -7 from cmd:'/opt/sbin/iptables -t filter -F FWKNOP_INPUT': )
delete_all_chains() CMD: '/opt/sbin/iptables -t filter -X FWKNOP_INPUT' (res: 0, err: run_extcmd(): could not fdopen() pipe output file descriptor.
delete_all_chains() CMD: '/opt/sbin/iptables -t filter -X FWKNOP_INPUT' (res: -7, err: )
delete_all_chains() Error -7 from cmd:'/opt/sbin/iptables -t filter -X FWKNOP_INPUT': )
