Hi folks - noob to this, so please go easy
I have managed to setup an openvpn client via the gui and that works great.
I've been able to set up some routing rules, again via the latest gui 'policy rules', and these allow me to select particular ip addresses to go through the vpn, the rest via the regular isp network connection. All works great....
I want to have the first 5g guest network (only) use the vpn, everything else to use the regular connection.
I have followed guide for this here:
https://github.com/RMerl/asuswrt-me...or-VPN-and-SSID-for-Regular-ISP-using-OpenVPN.
It's not working for me... I have followed it pretty much exactly.
Specifically, it does set up the guest network to hand out IPs in the range of 192.168.2.100/120
But, When a client connects, they get an ip in that range, but they can't see the Internet.
Was wondering if perhaps there is some kind of clash between to Gui configured openvpn client and the script? I think the policy rules section is really new so perhaps doesn't play nicely with the scripting?
Is there a way to (through the gui), configure dhcp ip range for the guest network? I think if I can just get the guest network using the 192.168.2.X range, I can config the policy rules in the openvpn gui page to just route vpn traffic from those addresses.
Thanks guys, sorry if this is some basic shizzle.
