Hi,I know there was a cost reason to go with 2.5 / 5 Gbps Ethernet. But is there any reason why we can not bring the cost of 10Gbps Ethernet Controller down?
The issue is not just with the cost of the controller.
The real benefit is on the supported cable.
10gbe requires CAT6a cable for lengths greater than 55meters.
NBase-T will run 100m at 2.5g over CAT5e and 100m at 5g over CAT6.
Ask any installer. CAT6a is a very difficult cable to work with compared to even CAT6 and in larger installs is a costly upgrade over the existing lines. Making it more difficult is when you have large bundles over long distances, to keep the lines fully 10g capable they need to be shielded. This is due to alien crosstalk between other lines in the bundle. That should in turn must be grounded on one end else the performance will drop worse than if it was just UTP cable.
I have 1 client out in the field with the new Cisco nbase-t ports. They are not using them as intended but getting great benefit out of them as used. All it took was 1 line card and a replacement of 6 access switches. The existing cable was installed during construction in 1998. To replace the cable was quoted as more than the switch upgrade. Why the contractor chose to pour concrete over the bare cable instead of using conduit . . . I don't know. All I know is, the client is very happy about the results.
Outlining my answer leads to the this conclusion: What is actually your question all about?
There is still the possibility of a consumer router that uses DFS channels over UNII 2/2e.
That allows for continuous 160mhz channels.
Welcome To SNBForums
