Mark112887
I previously posted a thread about this issue concerning my other router, I didn't get very much attention because I believe I worded the situation incorrectly, I would appreciate any help that anyone may be able to provide.
Previously I owned an RT–AC66U router and the one thing I always noticed is that I would experience random but occasional reboots. I would keep all features in the router turned off except for MAC filtering and samba share. I was previously told that it is normal to have high RAM usage when streaming but that it should return to normal levels once the activity stops.
The problem that I experienced with the router is that the memory would never go down it would only go up and I believe that this was the cause for my reboots, the longest I have ever been able to go without a reboot was 17 days. Even after a reboot the memory use would still be in the high 70% the only thing that would actually get to go back down would be a full restore and fresh setup of the router.
Has anybody had this problem with this router?
To remedy the issue I recently purchased the RT–AC3200 to see if I would have better luck with a newer device. So far everything has been fine but I have noticed the router slowly creeping up by 1% of RAM usage as each day goes by and I'm worried that I will soon face the same problem again with this device.
Can anyone please provide any insight at all?
