P
Pir8pete
Guest
Merlin;
I've noticed some errors in the logs with my 1900P after booting and I'm not sure if it normal and to just ignore it or somethings wrong. Here's the output below;
Also I noticed that if I have a USB drive plugged in, it shows in the network as a shared PC hard drive even when Samba share is disabled. To get ride of it I need to toggle enable then toggle back to disable then its gone. But if the router gets rebooted it comes back!
I'm using a 4gig USB drive formatted to ext2 for AB-solution only, I had nothing smaller laying around or I'd use that. Be nice to have AB-Solution to just use the jffs and no USB.
Jul 31 20:00:22 kernel: xhci_hcd 0000:00:0c.0: Failed to enable MSI-X
Jul 31 20:00:22 kernel: xhci_hcd 0000:00:0c.0: failed to allocate MSI entry
