namurt
My use case scenario is as follows:
Should I just follow the NAS rankings or is there something else to consider? Probably going to populate the NAS with WD Red drives, either 3TB or 4TB. I'm trying to watch my budget as much as possible. I don't need a ton of bells and whistles as my use case is a pretty basic SOHO type scenario. I do want to perform backup, but I want to do it as cheaply as possible. Even though I'm not storing critical files, after the failure of my current NAS, re-ripping all those movies is going to take a while and be a major PITA!
- NAS will primarily be used to house media (mostly video and some music) for playback on tablets, PCs and boxee (the latter gets the most use and is basically my version of an htpc)
- Not terribly concerned about backup, but am considering running either RAID1 (I know this isn't technically backup!) or RAID0 with backup to external (via connected USB drive)
- Referring to the previous point, would probably rather maximize storage space on the NAS itself since I'm not storing any critical files (so this would mean I'd have to get an external equal to the capacity of both drives together that I install in the NAS, correct?)
- Would prefer to have enough performance to be able to run Plex right on the NAS (old NAS, which just crapped out, was too weak and had to run Plex server locally on PC)
