If you have more than one device plugged into the appletv, it is not a security problem.
Hello L&LD, thanks for your reply,
sorry for my ignorance, but how can that be possible.. that device has only one RJ45 and it serves content, doesn't provide network access
thanks
this happens both with asus and merlin firmwares, unsure if is really an issue.
Can anyone help me to understand if I have a security problem in my network?
thanks in advance...
This happens when I use a virtual machine on my main computer.
Rgds,
GS
COLGeek said:
Kind of makes sense, if the device's (while in sleep mode) DHCP server "forgot" what IP addresses had been assigned, that could create the problem you had. Hope it holds up.
I see this on an Amcrest IP camera.. I have 'Enable UPnP=NO' in the GUI , so I assumed that the 2 (correctly) refers to the number of Android client devices that I have that are using the IP Cam Viewer app having a socket connection?
NOTE: 4 other IP cameras are also connected to the Android app but are older Foscam/Tenvis devices but they don't show 2 connections.
Are they newer VIZIOs with the built in Chromecast?but that doesn't explain FOUR showing on one IP address.
Yes, they are.Are they newer VIZIOs with the built in Chromecast?
That's exactly what I was thinking.Yes, they are.
It's possible I have a number (just over 4) of Android phones that like to connect to Chromecast devices.
I've got 5 clients supposedly connecting through an iPhone! How is that possible?
Welcome To SNBForums
