I have a FTTB internet connection from provider A. It's connected to an ASUS RT-AC66U via ethernet (WAN) and through a PPPoE connection. However, my IPTV is coming from provider B. It's a DOCSIS3 network, so they gave me a HGW (residential/home gateway - modem+router combo), and the STBs (set top box) are connected to that via ethernet. Since both devices run their own DHCP servers, the ASUS right now is using the 192.168.1.X range, the HGW is using 192.168.0.X. You can control the STBs with your phone/tablet on your local network (it uses the local IP), and I want to use this feature. So my question is: how can I make a connection between the two networks? Obviously, simply plugging two LANs together wont work.
