Hi guys, hope you can help me out with a problem I can't solve (maybe I missed something obvious). The problem arose when updating my two AC86U routers from 384 to 386(.10) based firmware (merlin). Before the update I had setup vpn tunnel between the two that are on different locations (1st location server, 2nd location client). One as server the other as client over wan only accessing LAN. Configuerd so clients on both ends could see each other. Additionaly I had setup another openvpn server on both routers so I could access (from e.g. smartphone) that specific location (router and clients), this time clients accessing internet as well. When using this second server I could not see clients on other location which is fine, because I was usually solving problems on that specific location (hence additional servers on both ends). All vpn servers had uniqe subnets and ports. This was all working as intended. After the upgrade, tunnel between locations works as before, the second vpn server on server side also works as before. The problem is on the client side (2nd location) where configured server for occational connection is not accessible as long as the router has active vpn client (connecting to 1st location). As soon as I disable this connection the server starts working (maybe not relevant or normal, but when I'm connected on client's network (2nd router) I can connect to its server). Subnets of servers do not overlap, ofcourse using different ports for each server. I'm not shure if I should make some additional settings in VPN Director (in previous FW I did not have to), as I have set "redirect internet traffic to tunnel" to "No" anyways (on client side, 2nd location). Thanks for your input.
PS: I can post config is necessary.
