Joe Campitelli
I'm looking for some guidance on how to best set up a pair of RT-AC68U. Whether I set them up as router/AP or as AiMesh router and node I have an overlapping space where the wireless handoff from one node to the other takes several seconds to complete. This only happens when the wireless client is travelling from one area to the other. When using MS Teams or FaceTime, it's enough to disrupt the connection.
I'm on the latest Asus firmware using ethernet backhaul. I'm currently in a Router/AP configuration. Is the expectation AiMesh supposed to handle the handoff better?
In the past I've tried running Merlin firmware, using L&LD and OE's recommended suggestions but I keep running into the same issue. I've also tried adjusting the roaming assistant but I think that it just causes the handoff to happen earlier (or later) depending which way I adjust the RA.
I don't expect a seamless handoff between nodes but is it fair to expect the handshake to take a few seconds and not 15-20 seconds?
