k13p
Hi all,
I have two RT-AC88U routers combined into AiMesh network:
Firmware Version: 3.0.0.4.384_45713 (afaik latest)
Router 1 is configured as AiMesh master.
Router 2 is configured as AiMesh node.
ISP1 -- (Ethernet cable) -- Router 1 WAN Port
ISP2 -- (not connected yet – waiting for ISP to install the network) –– Router 1 LAN Port 1
Router 1 LAN Port 2 -- (Ethernet cable) -- Router 2 WAN Port
ISP1: 50Mb/s upload / 50Mb/s download
ISP2: don't know yet
3 Wifi networks configured:
- network 2G
- network 5G
- guest network 2G
DualWAN setting: ON (Failover, ping google.com each 5 seconds for 12 times, back to primary WAN after 12 times) – it is enabled but the ISP2 is not yet plugged in so I expect it will not switch ever
There is about 20-30 notebooks connected to the network at all times through Wifi (not heavy load, mostly browsing the web), also there are some phones connected too (around 10-15). No printers / other devices like NAS etc.
We are a small company, we have just moved to a new office and I have set up the network myself as I am the most experienced with networking (but still little). Unfortunately, everybody is constantly complaining about network issues:
- yesterday some people had problems to connect to the network at all (something like routers are not able to handle more users but don't know how to check this), at some point nobody new was able to join – we have restarted (unplugged) the router to fix this; I have also noticed in "Professional settings tab" that "Radio" for both 2G and 5G was turned off and I switched it on – not certain what if it helped and what "Radio" means as I expected there will be no Wifi network while its off
- there are some Wifi radius problems too but I want to move routers to better places to fix that
- sometimes access to the web drops suddenly and we have to wait few minutes for it to restore (can be ISP's fault too but I guess it's not)
Router log: https://pastebin.com/HUfuWTQd
We are operating with this setup from 6th May.
1) Can somebody please check the log and search for "May 8 10:00:53" -> at this moment the network connection dropped for few minutes and I don't understand what happened
2) Why the log timestamp is "jumping" there and back (is not ordered according to the timestamp)?
3) Is this setup reasonable at all to handle this number of devices?
I will honestly appreciate any help or advice.
Thanks!
- network 2G
- network 5G
- guest network 2G
Thanks!
