Chris313AllNight
I got my N66U in a few days back. Got the noted firmware installed and set up. Issues. How does IPv6 work? In the settings, it's listed as Native with DHCP-PD. If you have IPv6, like Comcast touts, it should just work right? (It doesn't) Am I missing some setting somewhere?
Another big issue that I've got that was even worse with my previous router is the fact that my game console speeds when downloading anything on them, blow. For example, with the N66U, I've been getting 5-11Mbps on my Xbox. I get 20Mbps on my PS3 when downloading one file at a time from inside the PSN store, but when background downloading, it dropped to about 8Mbps or slower.
Shouldn't it be faster then this? I do have a 50/10 connection and get at least 35 plus on downloads done on my computer. Or am I just stuck and have to live with it?
Since I mentioned in a previous post all my devices don't play well together unless static IPs are given to each device and the needed ports set to open, etc, where do I look to do this and what settings do I change, or disable to make this happen?
Since getting Merlin's FW going, I'm looking into saving my BW logs to USB stick so they last through reboots and things. How do I do that?
I think that's everything. I look forward to seeing what your FW can really do.
