this close :D
Sorry if it's a stupid question, but I'm having a hell of a time trying to google this for some reason. The results all come back for powerline networking and tin-foil-hatters paranoid about wifi and powerlines affecting their brains. I went to install my AP AC Pro, and realized hat there is a mains lighting wire running along a beam ~ 150mm from where the APwas to be installed. There is also a pendant light fitting about 700mm from the location. Is this a problem?
Don't run ethernet parallel with main power, if you need to cross wire, do it at right angles - and with lighting - incandescent is fine, fluorescent, try to stay away from, and same goes with LED's...
Depends on the LED's - some are pretty noisy in the 2.4GHz range... esp. the ones that work with dimmer switches... might have to experiment, as there is no clear 'standard' there...
