awraynor
I'm currently running an OG Core i7 with 8GB of RAM on WHS 2011. With this software dying and becoming unreliable I'm looking at going to a NAS box. This box uses a lot of electricity and makes a lot of heat.
It needs to be a dumb box, sitting in the corner with probably 4-4TB drives. I'll likely use VEEAM for backup unless built in software is superior?
It needs to also do duty as a Plex Media Server with probably one stream being sufficient at any one time.
My friends on HomeServershow.com are steering me towards QNAP as you seem to get a little more hardware for your money and we know transcoding on Plex loves some CPU cycles. I store everything in mp4 and will most of the time stream to my Amazon FireTV in the living room or an ATV2 in the kids playroom.
I'm thinking the TS-451+, TS-453 Pro or maybe even TS-563 may be good options. Being able to upgrade the RAM would be a good thing and it doesn't have to be pretty as it will likely just sit in a corner somewhere.
After looking around I wonder if a NAS is the best option if Plex won't run on a sub-$1000 box. If so I would consider just building a low power Win10 box full of drives.
Any thoughts?
Any thoughts?
