D-Link DIR-882 AC2600 MU-MIMO Wi-Fi Router Reviewed
thiggins
Mr. Easy
Staff member
D-Link's DIR-882 AC2600 MU-MIMO Wi-Fi Router is a surprisingly good router for the money.
Read on SmallNetBuilder
The current known security issues have already been addressed...
Thanks for the review. Kind of disappointing 5Ghz range. Was MU-MIMO not tested? I went over the review twice and did not see anything. I have to mention that the Netgear R7800 that you mentioned in the beginning of the review is listed at $130 for a certified refurbished unit on Amazon. After reading the review, I'd rather go with that...
Page 4, paragraph right before Closing Thoughts.
I am not testing MU-MIMO on a regular basis. It does not provide benefit for the majority of users.
If you can get an R7800 cheap, go for it. I just published test results for it using the Revision 10 process.
Same here. They've issued a few FW releases for that series router so thats a closed issued now.
Nice. I have DIR-890L. Ty
Thanks for getting the scoop on the true DIR-878 capabilities.
It's interesting that D-Link claims "80/160 MHz Support" on the product page. The superscript "2" seems to point to the footnote on the Specs page that says "2. Latest software and documentation are available at http://support.dlink.com." We'll see if a future update actually brings support.
This thread is about the 882...
typo?
I stand corrected.
Please explain so we know specifically what you are referring to.
I think that's likely a generalization at some point.
D-Link has a good rep for HW, but their root software base has been problematic over the years - things might have changed, as last time I checked was late 2016.
Indeed. I was generalizing. They've had such a bad rep these past few years when it comes to security. I should have probably thought that everything would have been patched up by now.
I presume they are not the only ones to have security issues. They seem to be trying though.
It will be nice to see this review against other routers on Mediatek MT7621A platform (CPU MT7621A + 5G-MT7615 + 2.4G-MT7615)
One that is popular here is the new Linksys EA7500-AH V2 which has 3 external antenna and a internal one. Tests on Koolshare a chinese site looks impressive. Hope it gets a review here.
May not be by SNB. Maybe SNB will review the Meditek routers though...
Anyone know if there is a way to confirm that the 878 is utilizing all 4 radios?
I installed ddwrt and the wireless status shows the following. Maybe I'm not sure where to look? Is there a place to test? Thanks!
Chipset:
MT7615 802.11ac
Radio
Radio is On
Mode
AP
Network
AC/N-Mixed
SSID
Gin&Juice5
Channel
36 (5180 MHz)
TX Power
100 mW
Rate
1560 Mb/s
Encryption - Interface wl1
Enabled, WPA2 Personal
