4G-AC53U
SweSniper
Is there anyone running Merlin on the 4G-AC53U router? if yes, which build are you running on and does it work better then the asus original?
Your model is not supported by Asuswrt-Merlin check the first sticky posts, (should read before posting). Look here.
